Problem using function atof()
Hey I am pulling information off the internet and loading it into a string, then attempting to parse out temperature values for a subsequent calculation.
I’ve managed to get the temperature read into a string with this line:
String TempCS = FC.substring(0,FCLOC);
But the following assignment will not compile, even though TempC is declared as a float in the pre-setup assignment block.
float TempC = atof(TempCS);
I get the following error:
error: cannot convert ‘String’ to ‘const char*’ for argument ‘1’ to ‘double atof(const char*)’
Any help converting ‘String’ to ‘const char*’ would be greatly appreciated!
-Kyle
@grimace06, can you try and see following code works?
char szTempCS[13];
TempCS.toCharArray(szTempCS, 13);
float TempC = atof(szTempCS);
BTW this length 13 is just arbitrary, you may have to change it.
That worked GREAT!
Thank you, looks like the String type was incompatable but I wasn't sure what format it needed to be changed to. Thank you very much, krvarma!
Hi @grimace06
I am glad that @krvarma answer worked for you, using C style char arrays!
Another way is the toFloat method in the String class:
float TempC = TempCS.toFloat();
Thanks @bko!, that’s new to me, may be we should update the docs.
@ bko I tried your method as well and it works just fine… always great to learn new methods.
Thanks for your help!
