Any kind of start/stop byte that allows your receiving code to tell when one transmission starts and ends will do.
Even a fixed length protocol might be OK if you are sure never to loose a byte and get out of sync.
@douy, the EasyTransfer library should be straight forward to port. If you are still interested in using it, I can give it a shot tonight and let you try it
Sending data between an Arduino Uno and Photon with the libraries on both, communicating using Hm-10’s BLE modules.
Set up the two structures on both devices, the Photon receives a command via the internet then sends a command signal over to the Arduino, this should start a sub routine on the Arduino to read the temperature then send that data back to the photon. I’ve used multiple serial prints to see if any data is being received and to check where the code is having problems but the Arduino doesn’t seem to receive any of that data at all.
