Powering off a Boron RN402, BRN404 & BRN404X
After reading this I wonder what is the best way power off a Boron when just testing different code? Can I just unplug the USB cable or do I need to factor in this code Cellular.off(); waitFor(Cellular.isOff, 30000);
to every thing I want to test.
Also, will the u-blox SARA-R510S-01B LTE modem be susceptible to memory corruption if not properly shutdown?
Hi oraclerouter-
The risk of corruption is very low but if you want to fully eliminate it then yes, use the code. Anecdotally, I often play it fast and loose and just unplug the cable. I have not had any issues yet though your mileage may vary.
