Powering a Boron via PCB
Can I safely connect a 1S LiPo to the LiPo+ and GND pins on the Boron to power it? I want to be able to use a board-mounted battery holder and not have wires running around.
Yes, the Li+ pin can either be used to draw power from the LiPo attached to the JST-PH connector on the Particle device, or can be used in the opposite direction to put the LiPo on the board as you want to do and power the Boron.
