A common guideline for ‘garden-variety’, 1C charge-rate LiPos is to charge them at a maximum rate based off their capacity rating (i.e. a 1C LiPo @ 500mah can be charged at a rate of 500mA safely).
With the Power Shield’s set charge rates (0.5A USB, 1A DC), does that mean LiPos rated below 500mAH/1AH should not be used?
There are high quality LiPos targeted at the RC hobbyist that typically allow 5-6C charge rates. But I’m curious as to the use of affordable, 1C charge-rate LiPos out there that are under 500mAH.
p.s. I also checked the Power Shield’s BQ24030 datasheet, and reckon that the charge rates set during the design of the board are very sensible limits. I just need some clarification towards the safety aspects of using lower-capacity LiPos w/ the Power Shield.
As for the charging current, You can cut off the trace for ISET2 and ground it (but it’s super hard with such a small pad) to default the charging current to 100mA.
You will have to be careful to use a minimum 500mAh, 1C Lipo-battery since that’s the minimum charging current set.
Power Shields are temporarily unavailable due to complications around shipping lithium polymer batteries. We are sorting it out though and will have them back up!
@heather, how about an option to sell Power Shields sans 2AH LiPo battery? I’m sure the community will be able to source locally for the batteries.
May I suggest the importance of warning the user not to use <500mAH / 1AH LiPos with the Power Shield (and from @hfiennes’ 0.8C recommendation, perhaps <600mAH / 1.2AH?) This can be clearly included in the store’s product description/datasheet, and packaging in the form of a safety label.
…and as a suggestion, perhaps the next iteration of the Power Shield can include selectable charge rates for the BQ24030 through additional jumper pads? It might be a risky option for beginners to LiPos, but then again who’s to stop owners of v0.2.1 Power Shields now from plugging in 200mAH LiPos and having them swell up (and hopefully not blow up)?
Thanks @hfiennes for the additional details, this is very helpful information on managing LiPos. Good to know that 0.8C’s the best-practice recommendation for normal packs.
The Power Shield’s a great design with a compact footprint (the lack of mounting holes is my only grumble), so I’m looking forward to seeing it available again.
