Hi Guys,
Does anyone know how to send a PARTICLE_EVENT_VALUE as an integer from the custom JSON webhook.
If i send this it works "field1": 3
and this is doesn’t "field1": “{{PARTICLE_EVENT_VALUE}}”
Obviously I wanting to sent the Event Value
Cheers Connor
Have a read of this https://github.com/rickkas7/particle-webhooks. {{PARTICLE_EVENT_VALUE}} is not what you want
It’s now possible to use the Console to define hooks with integers values. See Console webhook editor improvements
Under the covers, it send the json property as a string. As long as after replacing {{PARTICLE_EVENT_VALUE}} and other variables the string ends up being valid JSON it will work.
json
