Could someone please port this library for me? I’m not having any luck… compiles fine in Workbench, but i get hard faults on my photon
@peekay123 seems to be the wizard
i’d happily pay
Figured it out from the guides… my issue, in case someone else finds this, was actually a code/wiring one.
I thought the arduino code was bit banging, not really using SPI, but in fact, it uses SPI. So I was getting a hard fault as I was setting the Clock and Data pin (as per the arduino code) to digital pins not used for SPI rather than the SPI class. Once I setup the code to use the SPI of the Particle Photon and used A3 and A5, it works fine!
