It looks like you have multiple versions of po-util installed.
Please delete the non macOS version.
What do type po and which po say?
Here's what happened? I removed redbear duo to see if po util works.
second I
particle device add 1c005200xxxxxxxx
Claiming device 1c0052000xxxxxxxxxx
Failed to claim device, server said: Device is not connected
Next I copied this to make new redbear duo.
dfu-util -d 2b04:d058 -a 0 -s 0x8008000 -D fac-dct-r1.bin
dfu-util -d 2b04:d058 -a 0 -s 0x08020000 -D duo-system-part1.bin
dfu-util -d 2b04:d058 -a 0 -s 0x08040000 -D duo-system-part2.bin
dfu-util -d 2b04:d058 -a 2 -s 0x140000 -D duo-fac-tinker.bin
dfu-util -d 2b04:d058 -a 2 -s 0x180000 -D duo-wifi-r1.bin
particle keys doctor 1c00520009xxxxxx
I installed the whole thing po-utils.
ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
c$ ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
==> This script will install:
/usr/local/bin/brew
/usr/local/share/doc/homebrew
/usr/local/share/man/man1/brew.1
/usr/local/share/zsh/site-functions/_brew
/usr/local/etc/bash_completion.d/brew
/usr/local/Homebrew
Press RETURN to continue or any other key to abort
==> /usr/bin/sudo /bin/mkdir -p /Library/Caches/Homebrew
Password:
==> /usr/bin/sudo /bin/chmod g+rwx /Library/Caches/Homebrew
==> /usr/bin/sudo /usr/sbin/chown imac /Library/Caches/Homebrew
==> Downloading and installing Homebrew...
remote: Total 0 (delta 0), reused 0 (delta 0), pack-reused 0
HEAD is now at 13576111 Merge pull request #2822 from ilovezfs/software_spec-recursive-reqs
Updated 1 tap (nrobinson2000/po).
==> Cleaning up /Library/Caches/Homebrew...
==> Migrating /Library/Caches/Homebrew to /Users/imac/Library/Caches/Homebrew...
==> Deleting /Library/Caches/Homebrew...
==> Updated Formulae
nrobinson2000/po/po
==> Installation successful!
==> Homebrew has enabled anonymous aggregate user behaviour analytics.
Read the analytics documentation (and how to opt-out) here:
Anonymous Analytics β Homebrew Documentation
==> Next steps:
- Run
brew helpto get started- Further documentation:
po init duo
Directory is already Initialized!
I've tried almost everything. is there something I'm missing?
how do I delete the non macOS version?
What do type po and which po say? It should help you locate the linux version if it is installed.
$ po
__ __ __
______ ______ __ __ ββ | ββ/ ββ |
/ \ / \ ______ / | / |/ ββ | / |ββ |
/ββββββ |/ββββββ |/ |ββ | ββ |ββββββ/ ββ |ββ |
ββ | ββ |ββ | ββ |ββββββ/ ββ | ββ | ββ | __ ββ |ββ |
ββ |__ββ |ββ __ββ | ββ __ββ | ββ |/ |ββ |ββ |
ββ ββ/ ββ ββ/ ββ ββ/ ββ ββ/ ββ |ββ |
βββββββ/ ββββββ/ ββββββ/ ββββ/ ββ/ ββ/
ββ |
ββ |
ββ/ https://po-util.com
Copyright (GPL) 2017 Nathan D. Robinson
Usage: po DEVICE_TYPE COMMAND DEVICE_NAME
po DFU_COMMAND
po install [full_install_path]
po library LIBRARY_COMMAND
Run "man po" for help.
Can you run:
$ type po
And:
$ which po
$ type po
po is aliased to `~/po-util.shβ
$ which po
/usr/local/bin/po
Perfect!
Can you delete ~/po-util.sh and remove the alias in your .bashrc?
Update:
I fixed the problem linux was having with building for duo.
Could you make something cool for Po-Util?
Okay, I hold and press reset and mode. Yellow light flash. I plug in duo, core, etc on Raspberry Pi OS USB.
Make very quick boot splash
I USB plug in Duo. Progress bar should show up. Please wait⦠Upgrading & Fixing DFU errors on Duo.
No mouse & keyboard typing needed.
__ __ __
______ ______ __ __ _ββ |_ ββ/ ββ |
ββ |__ββ |ββ \__ββ | ββ \__ββ | ββ |/ |ββ |ββ |
ββ |
ββ |
ββ/ |ββββββββββββββ | 70%
100% complete show up done. You may unplug USB. Unplug show screensaver or kitchen dashboard(weather, clock). If user plug in Arduino Uno or Adafruit. It should show. Sorry, not compatible.
| POS | β> | Damaged or errors on Particle, Pi, duo, etc |
Boom all fixed.
Could you explain what you are looking for po-util to do more clearly? I understand that you would like a progress bar but I'm not sure what else.
When using po duo flash, po dfu-open is used to put the device into dfu mode for you.
###Introducing the bash completion beta!
You can now press tab (twice) while typing any po-util argument to have it automatically completed. Please contact me if I forgot any completions, as this is a beta.
Please update po-util and reinstall to get the bash completion.
Iβve ironed out some bugs I was having with the bash completion on macOS.
Iβve also added CONTRIBUTING.md and a Code of Conduct to po-util.
Iβd also like to announce that I am offering my bash skills to anyone on the community who needs them.
Iβve made a bunch of updates to po-util. Please run:
$ po update
$ po install
to get them.
Added 3 libs with new feature: Now I have β¦
bash-3.2$ cat libs.txt
https://github.com/grovelabs/Spark-Adafruit-PCA9685.git Spark-Adafruit-PCA9685
https://github.com/blynkkk/blynk-library.git blynk-library
https://github.com/dwcares/debounce.git debounce
But when I do po photon build, I get
make[2]: *** No rule to make target `/Users/AndrewWard/Documents/AW_HW_SW_Projects/PWM_Test/firmware/blynk-library/*.cpp',
needed by `../build/target/user/platform-6-m/firmware/blynk-library/*.o'. Stop.
make[1]: *** [user] Error 2
make: *** [modules/photon/user-part] Error 2
Any suggestions on how to get the blynk library to build?
Hi @awardblvr,
Please update po-util with:
po update
And then use the blynk library optimized for po-util:
po lib rm blynk-library
po lib purge blink-library
po lib get https://github.com/nrobinson2000/blynk
po lib add blynk
I have found a method for Linux to open devices on the default baud rate of 14400 to put them into DFU mode. No more 19200 baud workaround!
Also, po-util now installs all of its dependencies and components in ~/.po-util to stay more organized. Below are the instructions to remove the old components and update po-util on macOS and Linux:
$ cd ~/github
$ rm -rf particle pi redbearduo dfu-util
$ rm -f ~/.po
$ rm -rf ~/bin/gcc-arm-embedded #Linux Only
$ sudo rm -f /usr/local/bin/arm-non-eabi* #Linux Only
$ bash <(curl -sL https://master.po-util.com/install)
I had the arduino IDE up and functional.
arduino IDE 1.8.3
I had Teensyduino 1.3.7 working too
I have the Raspberry agent installed on the latest raspbian
these worked today.
I am on RPI 3
I can still compile on the arduino IDE for teensy and other boards but the serial monitor freezes.
I installed po-utils today.
the serial monitor in the arduino IDE stops after only a few lines
pi@TELEZrpi3:~ $ type po
po is /usr/local/bin/po
pi@TELEZrpi3:~ $ which po
/usr/local/bin/po
pi@TELEZrpi3:~ $ po list
Found the following Particle Devices:
Electron: /dev/ttyACM0
USB_Serial: /dev/ttyACM1
pi@TELEZrpi3:~ $
I wonder what happened to my serial port for serial monitor in the Arduino IDE
well did some other installsβ¦
I am building ATOM on the rpi3β¦
I got the serial monitor working at 19200β¦for now
I will try to monitor the electron and see if that works
I did get apm and atom on my rpi3.
after a bit of flipping through
Nice. I havenβt tested po-util on raspberry pi much. Are you able to build projects?
