I am having trouble interfacing PMS 3003 Particle Sensor with arduino to get the PM value. Its always showing zero even when there is data being transmitted into the serial buffer, but for some reason the checksum function is not giving the desired result.
Please help me out.
Following is the code :
#include <SoftwareSerial.h>
#define LENG 31 //0x42 + 31 bytes equal to 32 bytes
SoftwareSerial mySerial(10, 11); // RX, TX
unsigned char buf[LENG]; //register that stores 31 bytes
int PM01Value=0; //define PM1.0 value of the air detector module
int PM2_5Value=0; //define PM2.5 value of the air detector module
int PM10Value=0; //define PM10 value of the air detector module
//#define Debug_Mode
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
mySerial.begin(9600); // will communicate with device via pin 10,11
mySerial.setTimeout(1500);
if(mySerial.find(0x42)) // checks for the 1st byte
mySerial.readBytes(buf,LENG); // starts reading the buf register
if(buf[0] == 0x4d) // checks if 2nd byte is 0x4d
if(checkValue(buf,LENG)) // checks the equality of the data sent and received
PM01Value=transmitPM01(buf); //transmits PM1.0 value after checking the 1st two bytes 0x42 & 0x4d
//PM2_5Value=transmitPM2_5(buf); //count PM2.5 value " " " " "
//PM10Value=transmitPM10(buf); //count PM10 value " " " " "
static uint32_t t1=millis();
if (millis() - t1>=1000)
t1=millis();
Serial.print("PM1.0: ");
Serial.print(PM01Value);
Serial.println(" ug/m3");
/*Serial.print("PM2.5: ");
Serial.print(PM2_5Value);
Serial.print("PM1 0: ");
Serial.print(PM10Value);
Serial.println("***************************************************************************************************************************************************"); */
char checkValue(unsigned char *thebuf, char leng) // checkvalue function call
char receiveflag=0;
int receiveSum=0;
for(int i=0; i<(leng-2); i++)
receiveSum=receiveSum+thebuf[i];
receiveSum=receiveSum + 0x42; // sum received by serial from the sensor data
#ifdef Debug_Mode
for(int i=0; i<(leng); i++)
Serial.print("Buffer: ");
Serial.print(i);
Serial.print(" : ");
Serial.println(thebuf[i]);
Serial.print("Receive Sum: ");
Serial.println(receiveSum);
Serial.println("-----------------------------------------------------------------------------------");
#endif
if(receiveSum ==((thebuf[leng-2]<<8)+thebuf[leng-1])) //(thebuf[leng-2]<<8)+thebuf[leng-1])= sum calculated by the Sensor and sent to serial
receiveSum = 0;
receiveflag = 1; // if data on both sides match
return receiveflag;
int transmitPM01(unsigned char *thebuf) //transmit PM values to serial buffer
int PM01Val=0;
PM01Val=((thebuf[3]<<8) + thebuf[4]); //count PM1.0 value
return PM01Val;
int transmitPM2_5(unsigned char *thebuf)
int PM2_5Val;
PM2_5Val=((thebuf[5]<<8) + thebuf[6]); //count PM2.5 value
return PM2_5Val;
int transmitPM10(unsigned char *thebuf)
int PM10Val;
PM10Val=((thebuf[7]<<8) + thebuf[8]); //count PM10 value
return PM10Val;
