Please help on reconnecting problem
I would like my photon to have the following features:
  • when the WiFi is down, I want it to be able to listen if the WiFi is up again.
  • also, during this time that the WiFi is down, I want it to be able to acquire new credentials with the use of the Particle mobile app.
  • Before anything, I call WiFi.useDynamicIP();
  • When I change the password to my WiFi, the photon gets disconnected from the WiFi, I get notified from the event: “network_status_disconnected”.
  • Then I enter to the listen mode with WiFi.listen() function.
  • I then change again the WiFi password to the old one and my photon enters the state of the fast green light, which, from the documentation, I see that it means: “LED_SIGNAL_NETWORK_DHCP Getting network address”.
    Problem is that it stays there forever.
I am working with threads.
Please help!!!
Vasilis.
Anyone?
How do you drop out of Listening Mode between your steps 3 & 4?
Try “power-cycling” the radio module (WiFi.off() - delay - WiFi.on() - Particle.connect()) and don’t retrigger a connection while another attempt is running.
Hi!
I am calling the listen function with a 30 seconds timeout, after that, since I am running on threads, I call a 35 second delay.
I will try the WiFi.off() and on() and let you know what happened.
Strange, I was under the impression that the Photon should automatically reconnect in the AUTOMATIC mode.
