I have a custom board that is using WKP and D6 pins on the Photon. These pins were used as a soft serial.
If I use the same board with a Xenon (with the Particle Adaptor), is there a way (code) where I can send the WKP signals to D4 and the D6 signals to D5 which are the UART2 pins on the Xenon or does the board have to be changed?
@Jimmie, ParticleSoftSerial does not work with Mesh devices at this time. Also, you cannot remap the Feather pin-out to get the UART2 pins to WKP and D6 or vice-versa. You will need a board change.
@Jimmie, that’s never a good idea but it might be doable if you put both WKP and D4 in INPUT mode in a STARTUP() function so they are configured as early as possible.
