Pin configuration of grove ultrasonic ranger with particle Shield
Hi Everyone,
I have a grove starter kit and i try to using Ultrasonic ranger. I don’t find informations for using argon/xenon/boron with grove starter kit, specially of how initialise the correct PIN.
I use the D2 connector on my grove shield for particle. here is the (simple code):
#include "Ultrasonic.h"
Ultrasonic ultrasonic(2);
get_ultrasonic_value();
void get_ultrasonic_value() {
long RangeInCentimeters;
RangeInCentimeters = ultrasonic.MeasureInCentimeters(); // two measurements should keep an interval
delay(250);
Particle.publish("ultrasonic",String(RangeInCentimeters));
For now, i only have a “0” value.
Pierrick
One thing I can say for sure it that you should not use 2 for the pin designation but go with the actual pin label D2.
If D2 happens to line up with the anonymous pin number 2 (as does on Gen1 & 2 devices) that’s not always guaranteed and hence should not be counted on.
Also which of the Ultrasonic libraries are you using?
Hi @ScruffR, thanks for your help.
i use :
GROVE-ULTRASONIC-RANGER v 1.0.1
Available on libraries. I tried with "D2" but still nothing else than "0".
I am not sure how this grove ultrasonic ranger works. The HC-SR04 uses 2 pins, first the ping or trigger and second a receiver pin whereas this just has one pin. Try printing out to serial like the example below.
> long RangeInInches;
> Ultrasonic ultrasonic(D7);
> void setup()
>     Serial.begin(9600);
> void loop()
>      Serial.println("The distance to obstacles in front is: ");
>     RangeInInches = ultrasonic.MeasureInInches();
>     Serial.print(RangeInInches);//0~157 inches
>     Serial.println(" inch");
>     delay(250);
>     Serial.print(RangeInCentimeters);//0~400cm
>     Serial.println(" cm");
>     delay(250);
Has anybody figured out a solution to this problem? I’m having the same issue
