Photon Weather Station - Winddir and WindGust with Wunderground
Hi Guys
Recently got involve with Photon and must say i love this little device. Busy with a weather station.
The weather consist of the Photon and the Sparkfun weather shield and weather meters. Look at the documentation on Sparkfun and while good, it is really out of date.
My sensors are working correctly when connecting through the terminal (termite). First did a normal post but saw you can use webhooks. Setup a webhook and seems fine, however i still have an issues whereby my Winddir - wind direction and Windgust speed is not showing. Tried with the normal post command in photon IDE and also the same issue with the webhook.
Notice this is central issues, but could not find an answer. Hoop you clever okes can assist.
