Hi everyone…
is there anyone who were able to create a communication between photon and raspberry pi (model 3)?
i found something like that in the official website but it was not helpfull for me because i followed the steps shown there and it created a virtual photon device well how can i connect the sensor to virtual device and make it read a value and send it to raspberry pi ?
originally i want to try and practice with l2C it there a possibility for me to do so or if you may know of a method similar to it i would like you to guide me through it
The last example in this tutorial uses I2C to communicate between a Raspberry Pi and a Photon:
thank you.
i will try this at the moment
Does this work?
sudo i2cdetect -y 1
If not, you should follow the link to configuring I2C on the Pi as you probably need to install a few tools and enable the I2C bus in /boot/config.txt.
@rickkas7 I am trying to expand the Raspberry pi I2C master to photon slave example in your particle-i2c-tutorial to read more registers than just register 0. I was able to successfully run the example you provided; however, I am unable to successfully read more than just register 0.
Here is my photon code
#include "Particle.h"
#include "I2CSlaveRK.h"
// Set up this Photon as an I2C device device, address 0x10, with 10 uint32 registers
I2CSlave device(Wire, 0x10, 10);
unsigned long lastCounterUpdate = 0;
uint32_t counter = 0;
device.begin();
device.setRegister(0,16777216);
device.setRegister(1,1);
if (millis() - lastCounterUpdate >= 1000) {
// Once per second increment register 0
lastCounterUpdate = millis();
Serial.printlnf("register 0 set to %u", counter);
device.setRegister(0, counter++);
uint16_t regAddr;
while(device.getRegisterSet(regAddr)) {
// regAddr was updated from the I2C master
Serial.printlnf("from Pi master updated %u to %u", regAddr, device.getRegister(regAddr));
Here is my Raspberry Pi Code. My assumption is that the i2c registers would be sequential in memory, but that doesn't seem to be the case.
#include <errno.h>
#include <fcntl.h>
#include <linux/i2c-dev.h>
#include <stdio.h>
#include <stdlib.h>
#include <sys/ioctl.h>
#include <unistd.h>
int main(int argc, char *argv[]) {
int file;
int addr = 0x10;
// Code adapted from:
// http://elinux.org/Interfacing_with_I2C_Devices
if ((file = open("/dev/i2c-1",O_RDWR)) < 0) {
printf("Failed to open the bus.");
exit(1);
if (ioctl(file,I2C_SLAVE,addr) < 0) {
printf("Failed to acquire bus access and/or talk to slave.\n");
exit(1);
char buf[16];
buf[0] = buf[1] = 0;
if (write(file, buf, 2) != 2) {
printf("Failed to write to the i2c bus.\n");
exit(1);
if (read(file, buf, 16) != 16) {
printf("Failed to read from the i2c bus.\n");
exit(1);
printf("reg0=%ld\n\n", *(unsigned long*)buf);
for(int i=0; i<16; i++){
printf("reg%i=%02X\n", i, buf[i]);
return 0;
This is the output I get from running the compiled file.
Any help you could offer would be greatly appreciated.
Yes, you need to read each register separately.
The write command sends a uint16_t value containing the register number to read, in little endian byte order. So basically just set buf[0] to be the register number 0-15 you want to read from.
And, of course, do both the write and the read in your loop.
That should do it.
Ah yes, the register number in little endian is what tripped me up. Thanks for the help.
