Dear all,
I am a new user of Photon. I’d like to know if I can use a Photon in place of a Spark Core with no app code or pin changes. In other words, can I directly substitute a Spark Core for a Photon without design modifications?
They’re mostly pin compatible, however:
The Core has significantly less RAM, so large Photon programs won’t run on the Core.
The Photon supports CAN, and the Core does not.
The Photon supports on-device Wi-Fi setup (SoftAP), the Core does not.
The Core supports Serial2 on D0/D1, the Photon uses the pads on the bottom instead.
The Photon supports threads, the Core requires a separate library, but memory will be an issue.
That’s off the top of my head. There are probably other differences.
The Photon supports battery backed Backup RAM and RTC, the Core not
The Core has a filtered 3.3* pin, the Photon has this as supply VBAT for Backup RAM & RTC
The pins available for interrupts differ slightly
On Photon all GPIO pins but A3/A6 (aka DAC) are 5V tolerant, on the Core only D0, D1, D3, D4, D5, D6 & D7
The Photon has two DAC pins
The Photon “only” stores up to 5 sets of WiFi credentials, the Core up to 7
The Photon supports chip and external antenna, for the Core exist two dedicated devices either with a chip antenna or a uFL connector for ext. antenna
But it might be a lot easier if you tell us what your Core projects are currently using to answer whether the Photon will be a drop-in replacement or not.
As you see, in most aspects the Photon will be suitable as drop-in, but for some special cases it won’t - so it depends on your project.
