I have a photon remotely installed in a crowded urban location. It’s receiving serial communication from the load cell and then using a webhook to transmit the weight to a google sheet. Currently, the photon seems to be loosing connection after about 3-4 hr of being connected to the router.
This happened first on Thursday. Today, when I arrived at the site the Photon was breathing blue (meaning it has no wifi connection). When I restarted the photon it connected with no issues. I then implemented a connectivity check into my code to make sure that it was connected to the wifi as well as an IFTTT notification if it disconnects from the cloud. Today, at 5:16 pm, I received a notification from IFTTT that the photon was offline. I then did an OTA update which went through (telling me that the photon was successfully connected). I then received a IFTTT notification that the photon was again offline at 7:45 pm.
I have tried to implement a connectivity check so if the photon is disconnected it will restart and reestablish a connection (as a fail safe). But, this does not seem to be working as expected. I also added code to store the pertinent weight and number of disconnects to the EEPROM before it restarts. Insights into the code would be much appreciated.
// includes the papertrail and soft http libraries to generate remote logs and an onsite GUI respectively
#include "Particle.h"
#include "papertrail.h"
#include "softap_http.h"
// Uses the external antenna or internal - whichever is best
STARTUP(WiFi.selectAntenna(ANT_AUTO));
// start remote logger
PapertrailLogHandler papertailHandler("logs5.papertrailapp.com", 12345, "timm");
// Create a GUI for conne
struct Page
const char* url;
const char* mime_type;
const char* data;
const char index_html[] = "<!DOCTYPE html><html><head><meta name='viewport' content='width=device-width, initial-scale=1'><title>Setup your device</title><link rel='stylesheet' type='text/css' href='style.css'></head><body><h1>Connect me to your WiFi!</h1><h3>My device ID:</h3><input type=text id='device-id' size='25' value='' disabled/><button type='button' class='input-helper' id='copy-button'>Copy</button><div id='scan-div'><h3>Scan for visible WiFi networks</h3><button id='scan-button' type='button'>Scan</button></div><div id='networks-div'></div><div id='connect-div' style='display: none'><p>Don't see your network? Move me closer to your router, then re-scan.</p><form id='connect-form'><input type='password' id='password' size='25' placeholder='password'/><button type='button' class='input-helper' id='show-button'>Show</button><button type='submit' id='connect-button'>Connect</button></form></div><script src='rsa-utils/jsbn_1.js'></script><script src='rsa-utils/jsbn_2.js'></script><script src='rsa-utils/prng4.js'></script><script src='rsa-utils/rng.js'></script><script src='rsa-utils/rsa.js'></script><script src='script.js'></script></body></html>";
const char rsa_js[] = "function parseBigInt(a,b){return new BigInteger(a,b);}function linebrk(a,b){var c='';var d=0;while(d+b<a.length){c+=a.substring(d,d+b)+'\\n';d+=b;}return c+a.substring(d,a.length);}function byte2Hex(a){if(a<0x10)return '0'+a.toString(16);else return a.toString(16);}function pkcs1pad2(a,b){if(b<a.length+11){alert('Message too long for RSA');return null;}var c=new Array();var d=a.length-1;while(d>=0&&b>0){var e=a.charCodeAt(d--);if(e<128)c[--b]=e;else if((e>127)&&(e<2048)){c[--b]=(e&63)|128;c[--b]=(e>>6)|192;}else{c[--b]=(e&63)|128;c[--b]=((e>>6)&63)|128;c[--b]=(e>>12)|224;}}c[--b]=0;var f=new SecureRandom();var g=new Array();while(b>2){g[0]=0;while(g[0]==0)f.nextBytes(g);c[--b]=g[0];}c[--b]=2;c[--b]=0;return new BigInteger(c);}function RSAKey(){this.n=null;this.e=0;this.d=null;this.p=null;this.q=null;this.dmp1=null;this.dmq1=null;this.coeff=null;}function RSASetPublic(a,b){if(a!=null&&b!=null&&a.length>0&&b.length>0){this.n=parseBigInt(a,16);this.e=parseInt(b,16);}else alert('Invalid RSA public key');}function RSADoPublic(a){return a.modPowInt(this.e,this.n);}function RSAEncrypt(a){var b=pkcs1pad2(a,(this.n.bitLength()+7)>>3);if(b==null)return null;var c=this.doPublic(b);if(c==null)return null;var d=c.toString(16);if((d.length&1)==0)return d;else return '0'+d;}RSAKey.prototype.doPublic=RSADoPublic;RSAKey.prototype.setPublic=RSASetPublic;RSAKey.prototype.encrypt=RSAEncrypt;";
const char style_css[] = "html{height:100%;margin:auto;background-color:white}body{box-sizing:border-box;min-height:100%;padding:20px;background-color:#1aabe0;font-family:'Lucida Sans Unicode','Lucida Grande',sans-serif;font-weight:normal;color:white;margin-top:0;margin-left:auto;margin-right:auto;margin-bottom:0;max-width:400px;text-align:center;border:1px solid #6e6e70;border-radius:4px}div{margin-top:25px;margin-bottom:25px}h1{margin-top:25px;margin-bottom:25px}button{border-color:#1c75be;background-color:#1c75be;color:white;border-radius:5px;height:30px;font-size:15px;font-weight:bold}button.input-helper{background-color:#bebebe;border-color:#bebebe;color:#6e6e70;margin-left:3px}button:disabled{background-color:#bebebe;border-color:#bebebe;color:white}input[type='text'],input[type='password']{background-color:white;color:#6e6e70;border-color:white;border-radius:5px;height:25px;text-align:center;font-size:15px}input:disabled{background-color:#bebebe;border-color:#bebebe}input[type='radio']{position:relative;bottom:-0.33em;margin:0;border:0;height:1.5em;width:15%}label{padding-top:7px;padding-bottom:7px;padding-left:5%;display:inline-block;width:80%;text-align:left}input[type='radio']:checked+label{font-weight:bold;color:#1c75be}.scanning-error{font-weight:bold;text-align:center}.radio-div{box-sizing:border-box;margin:2px;margin-left:auto;margin-right:auto;background-color:white;color:#6e6e70;border:1px solid #6e6e70;border-radius:3px;width:100%;padding:5px}#networks-div{margin-left:auto;margin-right:auto;text-align:left}#device-id{text-align:center}#scan-button{min-width:100px}#connect-button{display:block;min-width:100px;margin-top:10px;margin-left:auto;margin-right:auto;margin-bottom:20px}#password{margin-top:20px;margin-bottom:10px}";
const char rng_js[] = "var rng_state;var rng_pool;var rng_pptr;function rng_seed_int(a){rng_pool[rng_pptr++]^=a&255;rng_pool[rng_pptr++]^=(a>>8)&255;rng_pool[rng_pptr++]^=(a>>16)&255;rng_pool[rng_pptr++]^=(a>>24)&255;if(rng_pptr>=rng_psize)rng_pptr-=rng_psize;}function rng_seed_time(){rng_seed_int(new Date().getTime());}if(rng_pool==null){rng_pool=new Array();rng_pptr=0;var t;if(window.crypto&&window.crypto.getRandomValues){var ua=new Uint8Array(32);window.crypto.getRandomValues(ua);for(t=0;t<32;++t)rng_pool[rng_pptr++]=ua[t];}if(navigator.appName=='Netscape'&&navigator.appVersion<'5'&&window.crypto){var z=window.crypto.random(32);for(t=0;t<z.length;++t)rng_pool[rng_pptr++]=z.charCodeAt(t)&255;}while(rng_pptr<rng_psize){t=Math.floor(65536*Math.random());rng_pool[rng_pptr++]=t>>>8;rng_pool[rng_pptr++]=t&255;}rng_pptr=0;rng_seed_time();}function rng_get_byte(){if(rng_state==null){rng_seed_time();rng_state=prng_newstate();rng_state.init(rng_pool);for(rng_pptr=0;rng_pptr<rng_pool.length;++rng_pptr)rng_pool[rng_pptr]=0;rng_pptr=0;}return rng_state.next();}function rng_get_bytes(a){var b;for(b=0;b<a.length;++b)a[b]=rng_get_byte();}function SecureRandom(){}SecureRandom.prototype.nextBytes=rng_get_bytes;";
const char jsbn_2_js[] = "function bnpRShiftTo(a,b){b.s=this.s;var c=Math.floor(a/this.DB);if(c>=this.t){b.t=0;return;}var d=a%this.DB;var e=this.DB-d;var f=(1<<d)-1;b[0]=this[c]>>d;for(var g=c+1;g<this.t;++g){b[g-c-1]|=(this[g]&f)<<e;b[g-c]=this[g]>>d;}if(d>0)b[this.t-c-1]|=(this.s&f)<<e;b.t=this.t-c;b.clamp();}function bnpSubTo(a,b){var c=0,d=0,e=Math.min(a.t,this.t);while(c<e){d+=this[c]-a[c];b[c++]=d&this.DM;d>>=this.DB;}if(a.t<this.t){d-=a.s;while(c<this.t){d+=this[c];b[c++]=d&this.DM;d>>=this.DB;}d+=this.s;}else{d+=this.s;while(c<a.t){d-=a[c];b[c++]=d&this.DM;d>>=this.DB;}d-=a.s;}b.s=(d<0)?-1:0;if(d<-1)b[c++]=this.DV+d;else if(d>0)b[c++]=d;b.t=c;b.clamp();}function bnpMultiplyTo(a,b){var c=this.abs(),d=a.abs();var e=c.t;b.t=e+d.t;while(--e>=0)b[e]=0;for(e=0;e<d.t;++e)b[e+c.t]=c.am(0,d[e],b,e,0,c.t);b.s=0;b.clamp();if(this.s!=a.s)BigInteger.ZERO.subTo(b,b);}function bnpSquareTo(a){var b=this.abs();var c=a.t=2*b.t;while(--c>=0)a[c]=0;for(c=0;c<b.t-1;++c){var d=b.am(c,b[c],a,2*c,0,1);if((a[c+b.t]+=b.am(c+1,2*b[c],a,2*c+1,d,b.t-c-1))>=b.DV){a[c+b.t]-=b.DV;a[c+b.t+1]=1;}}if(a.t>0)a[a.t-1]+=b.am(c,b[c],a,2*c,0,1);a.s=0;a.clamp();}function bnpDivRemTo(a,b,c){var d=a.abs();if(d.t<=0)return;var e=this.abs();if(e.t<d.t){if(b!=null)b.fromInt(0);if(c!=null)this.copyTo(c);return;}if(c==null)c=nbi();var f=nbi(),g=this.s,h=a.s;var i=this.DB-nbits(d[d.t-1]);if(i>0){d.lShiftTo(i,f);e.lShiftTo(i,c);}else{d.copyTo(f);e.copyTo(c);}var j=f.t;var k=f[j-1];if(k==0)return;var l=k*(1<<this.F1)+((j>1)?f[j-2]>>this.F2:0);var m=this.FV/l,n=(1<<this.F1)/l,o=1<<this.F2;var p=c.t,q=p-j,r=(b==null)?nbi():b;f.dlShiftTo(q,r);if(c.compareTo(r)>=0){c[c.t++]=1;c.subTo(r,c);}BigInteger.ONE.dlShiftTo(j,r);r.subTo(f,f);while(f.t<j)f[f.t++]=0;while(--q>=0){var s=(c[--p]==k)?this.DM:Math.floor(c[p]*m+(c[p-1]+o)*n);if((c[p]+=f.am(0,s,c,q,0,j))<s){f.dlShiftTo(q,r);c.subTo(r,c);while(c[p]<--s)c.subTo(r,c);}}if(b!=null){c.drShiftTo(j,b);if(g!=h)BigInteger.ZERO.subTo(b,b);}c.t=j;c.clamp();if(i>0)c.rShiftTo(i,c);if(g<0)BigInteger.ZERO.subTo(c,c);}function bnMod(a){var b=nbi();this.abs().divRemTo(a,null,b);if(this.s<0&&b.compareTo(BigInteger.ZERO)>0)a.subTo(b,b);return b;}function Classic(a){this.m=a;}function cConvert(a){if(a.s<0||a.compareTo(this.m)>=0)return a.mod(this.m);else return a;}function cRevert(a){return a;}function cReduce(a){a.divRemTo(this.m,null,a);}function cMulTo(a,b,c){a.multiplyTo(b,c);this.reduce(c);}function cSqrTo(a,b){a.squareTo(b);this.reduce(b);}Classic.prototype.convert=cConvert;Classic.prototype.revert=cRevert;Classic.prototype.reduce=cReduce;Classic.prototype.mulTo=cMulTo;Classic.prototype.sqrTo=cSqrTo;function bnpInvDigit(){if(this.t<1)return 0;var a=this[0];if((a&1)==0)return 0;var b=a&3;b=(b*(2-(a&0xf)*b))&0xf;b=(b*(2-(a&0xff)*b))&0xff;b=(b*(2-(((a&0xffff)*b)&0xffff)))&0xffff;b=(b*(2-a*b%this.DV))%this.DV;return(b>0)?this.DV-b:-b;}function Montgomery(a){this.m=a;this.mp=a.invDigit();this.mpl=this.mp&0x7fff;this.mph=this.mp>>15;this.um=(1<<(a.DB-15))-1;this.mt2=2*a.t;}function montConvert(a){var b=nbi();a.abs().dlShiftTo(this.m.t,b);b.divRemTo(this.m,null,b);if(a.s<0&&b.compareTo(BigInteger.ZERO)>0)this.m.subTo(b,b);return b;}function montRevert(a){var b=nbi();a.copyTo(b);this.reduce(b);return b;}function montReduce(a){while(a.t<=this.mt2)a[a.t++]=0;for(var b=0;b<this.m.t;++b){var c=a[b]&0x7fff;var d=(c*this.mpl+(((c*this.mph+(a[b]>>15)*this.mpl)&this.um)<<15))&a.DM;c=b+this.m.t;a[c]+=this.m.am(0,d,a,b,0,this.m.t);while(a[c]>=a.DV){a[c]-=a.DV;a[++c]++;}}a.clamp();a.drShiftTo(this.m.t,a);if(a.compareTo(this.m)>=0)a.subTo(this.m,a);}function montSqrTo(a,b){a.squareTo(b);this.reduce(b);}function montMulTo(a,b,c){a.multiplyTo(b,c);this.reduce(c);}Montgomery.prototype.convert=montConvert;Montgomery.prototype.revert=montRevert;Montgomery.prototype.reduce=montReduce;Montgomery.prototype.mulTo=montMulTo;Montgomery.prototype.sqrTo=montSqrTo;function bnpIsEven(){return((this.t>0)?(this[0]&1):this.s)==0;}function bnpExp(a,b){if(a>0xffffffff||a<1)return BigInteger.ONE;var c=nbi(),d=nbi(),e=b.convert(this),f=nbits(a)-1;e.copyTo(c);while(--f>=0){b.sqrTo(c,d);if((a&(1<<f))>0)b.mulTo(d,e,c);else{var g=c;c=d;d=g;}}return b.revert(c);}function bnModPowInt(a,b){var c;if(a<256||b.isEven())c=new Classic(b);else c=new Montgomery(b);return this.exp(a,c);}BigInteger.prototype.copyTo=bnpCopyTo;BigInteger.prototype.fromInt=bnpFromInt;BigInteger.prototype.fromString=bnpFromString;BigInteger.prototype.clamp=bnpClamp;BigInteger.prototype.dlShiftTo=bnpDLShiftTo;BigInteger.prototype.drShiftTo=bnpDRShiftTo;BigInteger.prototype.lShiftTo=bnpLShiftTo;BigInteger.prototype.rShiftTo=bnpRShiftTo;BigInteger.prototype.subTo=bnpSubTo;BigInteger.prototype.multiplyTo=bnpMultiplyTo;BigInteger.prototype.squareTo=bnpSquareTo;BigInteger.prototype.divRemTo=bnpDivRemTo;BigInteger.prototype.invDigit=bnpInvDigit;BigInteger.prototype.isEven=bnpIsEven;BigInteger.prototype.exp=bnpExp;BigInteger.prototype.toString=bnToString;BigInteger.prototype.negate=bnNegate;BigInteger.prototype.abs=bnAbs;BigInteger.prototype.compareTo=bnCompareTo;BigInteger.prototype.bitLength=bnBitLength;BigInteger.prototype.mod=bnMod;BigInteger.prototype.modPowInt=bnModPowInt;BigInteger.ZERO=nbv(0);BigInteger.ONE=nbv(1);";
const char jsbn_1_js[] = "var dbits;var canary=0xdeadbeefcafe;var j_lm=((canary&0xffffff)==0xefcafe);function BigInteger(a,b,c){if(a!=null)if('number'==typeof a)this.fromNumber(a,b,c);else if(b==null&&'string'!=typeof a)this.fromString(a,256);else this.fromString(a,b);}function nbi(){return new BigInteger(null);}function am1(a,b,c,d,e,f){while(--f>=0){var g=b*this[a++]+c[d]+e;e=Math.floor(g/0x4000000);c[d++]=g&0x3ffffff;}return e;}function am2(a,b,c,d,e,f){var g=b&0x7fff,h=b>>15;while(--f>=0){var i=this[a]&0x7fff;var j=this[a++]>>15;var k=h*i+j*g;i=g*i+((k&0x7fff)<<15)+c[d]+(e&0x3fffffff);e=(i>>>30)+(k>>>15)+h*j+(e>>>30);c[d++]=i&0x3fffffff;}return e;}function am3(a,b,c,d,e,f){var g=b&0x3fff,h=b>>14;while(--f>=0){var i=this[a]&0x3fff;var j=this[a++]>>14;var k=h*i+j*g;i=g*i+((k&0x3fff)<<14)+c[d]+e;e=(i>>28)+(k>>14)+h*j;c[d++]=i&0xfffffff;}return e;}if(j_lm&&(navigator.appName=='Microsoft Internet Explorer')){BigInteger.prototype.am=am2;dbits=30;}else if(j_lm&&(navigator.appName!='Netscape')){BigInteger.prototype.am=am1;dbits=26;}else{BigInteger.prototype.am=am3;dbits=28;}BigInteger.prototype.DB=dbits;BigInteger.prototype.DM=((1<<dbits)-1);BigInteger.prototype.DV=(1<<dbits);var BI_FP=52;BigInteger.prototype.FV=Math.pow(2,BI_FP);BigInteger.prototype.F1=BI_FP-dbits;BigInteger.prototype.F2=2*dbits-BI_FP;var BI_RM='0123456789abcdefghijklmnopqrstuvwxyz';var BI_RC=new Array();var rr,vv;rr='0'.charCodeAt(0);for(vv=0;vv<=9;++vv)BI_RC[rr++]=vv;rr='a'.charCodeAt(0);for(vv=10;vv<36;++vv)BI_RC[rr++]=vv;rr='A'.charCodeAt(0);for(vv=10;vv<36;++vv)BI_RC[rr++]=vv;function int2char(a){return BI_RM.charAt(a);}function intAt(a,b){var c=BI_RC[a.charCodeAt(b)];return(c==null)?-1:c;}function bnpCopyTo(a){for(var b=this.t-1;b>=0;--b)a[b]=this[b];a.t=this.t;a.s=this.s;}function bnpFromInt(a){this.t=1;this.s=(a<0)?-1:0;if(a>0)this[0]=a;else if(a<-1)this[0]=a+this.DV;else this.t=0;}function nbv(a){var b=nbi();b.fromInt(a);return b;}function bnpFromString(a,b){var c;if(b==16)c=4;else if(b==8)c=3;else if(b==256)c=8;else if(b==2)c=1;else if(b==32)c=5;else if(b==4)c=2;else{this.fromRadix(a,b);return;}this.t=0;this.s=0;var d=a.length,e=false,f=0;while(--d>=0){var g=(c==8)?a[d]&0xff:intAt(a,d);if(g<0){if(a.charAt(d)=='-')e=true;continue;}e=false;if(f==0)this[this.t++]=g;else if(f+c>this.DB){this[this.t-1]|=(g&((1<<(this.DB-f))-1))<<f;this[this.t++]=(g>>(this.DB-f));}else this[this.t-1]|=g<<f;f+=c;if(f>=this.DB)f-=this.DB;}if(c==8&&(a[0]&0x80)!=0){this.s=-1;if(f>0)this[this.t-1]|=((1<<(this.DB-f))-1)<<f;}this.clamp();if(e)BigInteger.ZERO.subTo(this,this);}function bnpClamp(){var a=this.s&this.DM;while(this.t>0&&this[this.t-1]==a)--this.t;}function bnToString(a){if(this.s<0)return '-'+this.negate().toString(a);var b;if(a==16)b=4;else if(a==8)b=3;else if(a==2)b=1;else if(a==32)b=5;else if(a==4)b=2;else return this.toRadix(a);var c=(1<<b)-1,d,e=false,f='',g=this.t;var h=this.DB-(g*this.DB)%b;if(g-->0){if(h<this.DB&&(d=this[g]>>h)>0){e=true;f=int2char(d);}while(g>=0){if(h<b){d=(this[g]&((1<<h)-1))<<(b-h);d|=this[--g]>>(h+=this.DB-b);}else{d=(this[g]>>(h-=b))&c;if(h<=0){h+=this.DB;--g;}}if(d>0)e=true;if(e)f+=int2char(d);}}return e?f:'0';}function bnNegate(){var a=nbi();BigInteger.ZERO.subTo(this,a);return a;}function bnAbs(){return(this.s<0)?this.negate():this;}function bnCompareTo(a){var b=this.s-a.s;if(b!=0)return b;var c=this.t;b=c-a.t;if(b!=0)return(this.s<0)?-b:b;while(--c>=0)if((b=this[c]-a[c])!=0)return b;return 0;}function nbits(a){var b=1,c;if((c=a>>>16)!=0){a=c;b+=16;}if((c=a>>8)!=0){a=c;b+=8;}if((c=a>>4)!=0){a=c;b+=4;}if((c=a>>2)!=0){a=c;b+=2;}if((c=a>>1)!=0){a=c;b+=1;}return b;}function bnBitLength(){if(this.t<=0)return 0;return this.DB*(this.t-1)+nbits(this[this.t-1]^(this.s&this.DM));}function bnpDLShiftTo(a,b){var c;for(c=this.t-1;c>=0;--c)b[c+a]=this[c];for(c=a-1;c>=0;--c)b[c]=0;b.t=this.t+a;b.s=this.s;}function bnpDRShiftTo(a,b){for(var c=a;c<this.t;++c)b[c-a]=this[c];b.t=Math.max(this.t-a,0);b.s=this.s;}function bnpLShiftTo(a,b){var c=a%this.DB;var d=this.DB-c;var e=(1<<d)-1;var f=Math.floor(a/this.DB),g=(this.s<<c)&this.DM,h;for(h=this.t-1;h>=0;--h){b[h+f+1]=(this[h]>>d)|g;g=(this[h]&e)<<c;}for(h=f-1;h>=0;--h)b[h]=0;b[f]=g;b.t=this.t+f+1;b.s=this.s;b.clamp();}";
const char script_js[] = "var base_url='http://192.168.0.1/';var network_list;var public_key;var rsa=new RSAKey();var scanButton=document.getElementById('scan-button');var connectButton=document.getElementById('connect-button');var copyButton=document.getElementById('copy-button');var showButton=document.getElementById('show-button');var deviceID=document.getElementById('device-id');var connectForm=document.getElementById('connect-form');var public_key_callback={success:function(a){console.log('Public key: '+a.b);public_key=a.b;rsa.setPublic(public_key.substring(58,58+256),public_key.substring(318,318+6));},error:function(a,b){console.log(a);window.alert('There was a problem fetching important information from your device. Please verify your connection, then reload this page.');}};var device_id_callback={success:function(a){var b=a.id;deviceID.value=b;},error:function(a,b){console.log(a);var c='COMMUNICATION_ERROR';deviceID.value=c;}};var scan=function(){console.log('Scanning...!');disableButtons();scanButton.innerHTML='Scanning...';connectButton.innerHTML='Connect';document.getElementById('connect-div').style.display='none';document.getElementById('networks-div').style.display='none';getRequest(base_url+'scan-ap',scan_callback);};var scan_callback={success:function(a){network_list=a.scans;console.log('I found:');var b=document.getElementById('networks-div');b.innerHTML='';if(network_list.length>0)for(var c=0;c<network_list.length;c++){ssid=network_list[c].ssid;console.log(network_list[c]);add_wifi_option(b,ssid);document.getElementById('connect-div').style.display='block';}else b.innerHTML='<p class=\\'scanning-error\\'>No networks found.</p>';},error:function(a){console.log('Scanning error:'+a);document.getElementById('networks-div').innerHTML='<p class=\\'scanning-error\\'>Scanning error.</p>';},regardless:function(){scanButton.innerHTML='Re-Scan';enableButtons();document.getElementById('networks-div').style.display='block';}};var configure=function(a){a.preventDefault();var b=get_selected_network();var c=document.getElementById('password').value;if(!b){window.alert('Please select a network!');return false;}var d={idx:0,ssid:b.ssid,pwd:rsa.encrypt(c),sec:b.sec,ch:b.ch};connectButton.innerHTML='Sending credentials...';disableButtons();console.log('Sending credentials: '+JSON.stringify(d));postRequest(base_url+'configure-ap',d,configure_callback);};var configure_callback={success:function(a){console.log('Credentials received.');connectButton.innerHTML='Credentials received...';postRequest(base_url+'connect-ap',{idx:0},connect_callback);},error:function(a,b){console.log('Configure error: '+a);window.alert('The configuration command failed, check that you are still well connected to the device\\'s WiFi hotspot and retry.');connectButton.innerHTML='Retry';enableButtons();}};var connect_callback={success:function(a){console.log('Attempting to connect to the cloud.');connectButton.innerHTML='Attempting to connect...';window.alert('Your device should now start flashing green and attempt to connect to the cloud. This usually takes about 20 seconds, after which it will begin slowly blinking cyan. \\n\\n\\nIf this process fails because you entered the wrong password, the device will flash green indefinitely. In this case, hold the setup button for 6 seconds until the device starts blinking blue again. Then reconnect to the WiFi hotspot it generates and reload this page to try again.');},error:function(a,b){console.log('Connect error: '+a);window.alert('The connect command failed, check that you are still well connected to the device\\'s WiFi hotspot and retry.');connectButton.innerHTML='Retry';enableButtons();}};var disableButtons=function(){connectButton.disabled=true;scanButton.disabled=true;};var enableButtons=function(){connectButton.disabled=false;scanButton.disabled=false;};var add_wifi_option=function(a,b){var c=document.createElement('INPUT');c.type='radio';c.value=b;c.id=b;c.name='ssid';c.className='radio';var d=document.createElement('DIV');d.className='radio-div';d.appendChild(c);var e=document.createElement('label');e.htmlFor=b;e.innerHTML=b;d.appendChild(e);a.appendChild(d);};var get_selected_network=function(){for(var a=0;a<network_list.length;a++){ssid=network_list[a].ssid;if(document.getElementById(ssid).checked)return network_list[a];}};var copy=function(){window.prompt('Copy to clipboard: Ctrl + C, Enter',deviceID.value);};var toggleShow=function(){var a=document.getElementById('password');inputType=a.type;if(inputType==='password'){showButton.innerHTML='Hide';a.type='text';}else{showButton.innerHTML='Show';a.type='password';}};var getRequest=function(a,b){var c=new XMLHttpRequest();c.open('GET',a,true);c.timeout=8000;c.send();c.onreadystatechange=function(){if(c.readyState==4)if(b){if(c.status==200){if(b.success)b.success(JSON.parse(c.responseText));}else if(b.error)b.error(c.status,c.responseText);if(b.regardless)b.regardless();}};};var postRequest=function(a,b,c){var d=JSON.stringify(b);var e=new XMLHttpRequest();e.open('POST',a,true);e.timeout=4000;e.setRequestHeader('Content-Type','multipart/form-data');e.send(d);e.onreadystatechange=function(){if(e.readyState==4)if(c){if(e.status==200){if(c.success)c.success(JSON.parse(e.responseText));}else if(c.error)c.error(e.status,e.responseText);if(c.regardless)c.regardless();}};};if(scanButton.addEventListener){copyButton.addEventListener('click',copy);showButton.addEventListener('click',toggleShow);scanButton.addEventListener('click',scan);connectForm.addEventListener('submit',configure);}else if(scanButton.attachEvent){copyButton.attachEvent('onclick',copy);showButton.attachEvent('onclick',toggleShow);scanButton.attachEvent('onclick',scan);connectForm.attachEvent('onsubmit',configure);}getRequest(base_url+'device-id',device_id_callback);getRequest(base_url+'public-key',public_key_callback);";
const char prng4_js[] = "function Arcfour(){this.i=0;this.j=0;this.S=new Array();}function ARC4init(a){var b,c,d;for(b=0;b<256;++b)this.S[b]=b;c=0;for(b=0;b<256;++b){c=(c+this.S[b]+a[b%a.length])&255;d=this.S[b];this.S[b]=this.S[c];this.S[c]=d;}this.i=0;this.j=0;}function ARC4next(){var a;this.i=(this.i+1)&255;this.j=(this.j+this.S[this.i])&255;a=this.S[this.i];this.S[this.i]=this.S[this.j];this.S[this.j]=a;return this.S[(a+this.S[this.i])&255];}Arcfour.prototype.init=ARC4init;Arcfour.prototype.next=ARC4next;function prng_newstate(){return new Arcfour();}var rng_psize=256;";
Page myPages[] = {
{ "/index.html", "text/html", index_html },
{ "/rsa-utils/rsa.js", "application/javascript", rsa_js },
{ "/style.css", "text/css", style_css },
{ "/rsa-utils/rng.js", "application/javascript", rng_js },
{ "/rsa-utils/jsbn_2.js", "application/javascript", jsbn_2_js },
{ "/rsa-utils/jsbn_1.js", "application/javascript", jsbn_1_js },
{ "/script.js", "application/javascript", script_js },
{ "/rsa-utils/prng4.js", "application/javascript", prng4_js },
{ nullptr }
void myPage(const char* url, ResponseCallback* cb, void* cbArg, Reader* body, Writer* result, void* reserved)
Serial.printlnf("handling page %s", url);
if (strcmp(url,"/index")==0) {
Serial.println("sending redirect");
Header h("Location: /index.html\r\n");
cb(cbArg, 0, 301, "text/plain", &h);
return;
int8_t idx = 0;
for (;;idx++) {
Page& p = myPages[idx];
if (!p.url) {
idx = -1;
break;
else if (strcmp(url, p.url)==0) {
break;
if (idx==-1) {
cb(cbArg, 0, 404, nullptr, nullptr);
else {
cb(cbArg, 0, 200, myPages[idx].mime_type, nullptr);
result->write(myPages[idx].data);
STARTUP(softap_set_application_page_handler(myPage, nullptr));
// Press SETUP for 3 seconds to make the Photon enter Listening mode
// Navigate to http://192.168.0.1 to setup Wi-Fi
// Include the rest of your application below,
// including your setup and loop functions
// Forward declarations
/*void processBuffer();*/
void webHook();
void tareFunction();
void connectionIssues();
void saveToTheEEPROM();
int getToTheEEPROM();
int changeTracker();
// Start custom code
// Global variables
const unsigned long SEND_INTERVAL_MS = 3200;
const size_t READ_BUF_SIZE = 18;
String units = "lbs";
char readSignal = 'R';
char tareSignal = 'T';
char zeroSignal = 'Z';
char grossSignal = 'G';
bool tare = false;
bool change = false;
char signals [] = {readSignal};
String tempMessage = "trash data";
unsigned long lastSend = 0;
int counter = 0;
int i;
int delta = 0;
int perviousWeight = 0;
int weight = 454545;
int disconnectEEPROMMemoryValue = 20;
int lastWeightEEPROMMemoryValue = 10;
int disconnectCounter = 0;
char readBuf[READ_BUF_SIZE];
size_t readBufOffset = 0;
USBSerial1.begin();
Serial1.begin(9600, SERIAL_8N1);
/*tareFunction();*/
weight = getToTheEEPROM(lastWeightEEPROMMemoryValue);
int lastDisconnectCounterValue = getToTheEEPROM(disconnectEEPROMMemoryValue);
Log.info("last disconnection counter %i", lastDisconnectCounterValue);
Log.info("last weight value %i", weight);
/*Log.info("Weight Zeroed on Startup --> %d", tareSignal);*/
// checking for serial data and writing it periodically
if (millis() - lastSend >= SEND_INTERVAL_MS) {
lastSend = millis();
Serial1.write(signals[0]);
connectionIssues();
// Read data from serial
while(Serial1.available()) {
if (readBufOffset < READ_BUF_SIZE) {
char c = Serial1.read();
if (c != '\r' && c!= '\n') {
readBuf[readBufOffset++] = c;
else {
readBuf[readBufOffset] = 0;
processBuffer();
readBufOffset = 0;
else {
Log.error("readBuf overflow, emptying buffer");
readBufOffset = 0;
void processBuffer() {
/*Log.info("Received from Optima: %s", readBuf);*/
String buffer = readBuf;
String subString = buffer.substring(2,10);
String trimSubString = subString.trim();
if(trimSubString.length() > 0 ){
weight = trimSubString.toInt();
if(changeTracker()){
saveToTheEEPROM( lastWeightEEPROMMemoryValue, weight);
webHook();
int changeTracker(){
if (abs(weight - perviousWeight) <= 2){
perviousWeight = weight;
change = false;
return change;
} else {
change = true;
delta = weight - perviousWeight;
return change;
void webHook(){
Log.info("Weight Sent Via WebHook: %i", weight);
String lbs = "lbs";
String form = String::format(
"{\"weight\":\"%i\",\"units\":\"" +lbs+ "\",\"delta\":\"%d\",\"units\":\"" +lbs+ "\",\"tare\":\"%d\"}",
weight, delta, tare);
Particle.publish("google-sheet-push", form, 60, PRIVATE);
// conitnualy monitors for wifi connection, should restart after 20 failed attemps to connect
void connectionIssues(){
/* designed to automatically reconnect to cloud if data connection is lost*/
if(Particle.connected() == true){
/* do nothing */
else if (disconnectCounter > 20) {
/*saveToEEPROM();*/
System.reset();
} else {
Particle.disconnect();
delay(100);
Particle.connect();
disconnectCounter++;
saveToTheEEPROM(20, disconnectCounter);
Log.info("disconnectCounter just incrimented %i", disconnectCounter);
void saveToTheEEPROM( int address, uint16_t valueToSave){
int addr = address;
uint16_t value = valueToSave;
EEPROM.put(addr, value);
int getToTheEEPROM(int address){
int addr = address;
uint16_t value;
EEPROM.get(addr, value);
if(value == 0xFFFF) {
// EEPROM was empty -> initialize value
Log.info("EEPROM is empty");
return 0;
return value;
void tareFunction(){
Serial1.write(tareSignal);
if (tare){ tare = false;}
else {tare = true;}
void zeroFunction(){
Serial1.write(zeroSignal);
else {tare = true;}
