Photon I2C Interface
I am trying to connect an Adafruit 8x8 matrix to my photon and its not working.
After verifying that the matrix was working and it was connected correctly I created a test program to check that i2c was working.
Something doesn’t seem to be right. The docs say that the Write() function should return the number of bytes written however when I try to write one byte I get back a very large number.
Here is my test code and its output
  Wire.begin();
  pinMode(led, OUTPUT);
  Spark.publish("STEJ Started");
void test()
  char buff[1024] = {0};
  Wire.beginTransmission(0x70);
  // the write function should return 1 but does not
  sprintf(buff, "%d", Wire.write(1));
  Spark.publish("write(1)", buff);
  sprintf(buff, "%d", Wire.endTransmission());
  Spark.publish("endTransmission", buff);
  test();
  digitalWrite(led, HIGH);
  delay(1000);
  digitalWrite(led, LOW);
  delay(1000);
What am I doing wrong?
I fixed it!
The shipped firmware is broken but this release works:
