mdma
July 22, 2015, 7:26pm
21
Thanks. It looks as though the build was not successful since the CRC was not appended to the file.
Please look for any error messages at the end of the build process.
The way to know is to run
xxd user-part.bin
and inspect the last 4 bytes output. If they are 7856 3412 then the CRC has not been correctly written.
Thanks @mdma ,
This is the build output from NeatBeans:
C:/Particle/toolchain/Make/bin/make -C ../modules/photon/user-part
make[1]: Entering directory `C:/Particle/firmware/modules/photon/user-part'
C:/Particle/toolchain/Make/bin/make -C ../../../user
make[2]: Entering directory `C:/Particle/firmware/user'
Building file: src/application.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-6-m/src/src/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=2 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,3 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../communication/lib/tropicssl/include -I../communication/src -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I../hal/src/photon/api -I../platform/shared -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../dynalib/inc -I./src -I./libraries -I. -MD -MP -MF ../build/target/user/platform-6-m/src/src/application.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -std=gnu++11 -fno-exceptions -fno-rtti -fcheck-new -c -o ../build/target/user/platform-6-m/src/src/application.o src/application.cpp
Building target: ../build/target/user/platform-6-m/src/libuser.a
Invoking: ARM GCC Archiver
arm-none-eabi-ar -cr ../build/target/user/platform-6-m/src/libuser.a ../build/target/user/platform-6-m/src/src/application.o
make[2]: Leaving directory `C:/Particle/firmware/user'
C:/Particle/toolchain/Make/bin/make -C ../../../hal-dynalib
make[2]: Entering directory `C:/Particle/firmware/hal-dynalib'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `C:/Particle/firmware/hal-dynalib'
C:/Particle/toolchain/Make/bin/make -C ../../../services-dynalib
make[2]: Entering directory `C:/Particle/firmware/services-dynalib'
make[2]: Leaving directory `C:/Particle/firmware/services-dynalib'
C:/Particle/toolchain/Make/bin/make -C ../../../system-dynalib
make[2]: Entering directory `C:/Particle/firmware/system-dynalib'
make[2]: Leaving directory `C:/Particle/firmware/system-dynalib'
C:/Particle/toolchain/Make/bin/make -C ../../../rt-dynalib
make[2]: Entering directory `C:/Particle/firmware/rt-dynalib'
make[2]: Leaving directory `C:/Particle/firmware/rt-dynalib'
C:/Particle/toolchain/Make/bin/make -C ../../../wiring
make[2]: Entering directory `C:/Particle/firmware/wiring'
make[2]: Leaving directory `C:/Particle/firmware/wiring'
C:/Particle/toolchain/Make/bin/make -C ../../../communication-dynalib
make[2]: Entering directory `C:/Particle/firmware/communication-dynalib'
make[2]: Leaving directory `C:/Particle/firmware/communication-dynalib'
C:/Particle/toolchain/Make/bin/make -C ../../../platform
make[2]: Entering directory `C:/Particle/firmware/platform'
make[2]: Leaving directory `C:/Particle/firmware/platform'
Building target: ../../../build/target/user-part/platform-6-m/user-part.elf
Invoking: ARM GCC C++ Linker
mkdir -p ../../../build/target/user-part/platform-6-m/
arm-none-eabi-g++ -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DINCLUDE_PLATFORM=1 -fno-builtin -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=2 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,3 -DRELEASE_BUILD -Werror -I./inc -I../../../user/inc -I../../../dynalib/inc -I../../../services/inc -I../../../hal/inc -I../../../hal/shared -I../../../hal/src/photon -I../../../hal/src/stm32f2xx -I../../../hal/src/photon/api -I../../../system/inc -I../../../rt-dynalib/inc -I../../../wiring/inc -I../../../modules/photon/system-part1/inc -I../../../platform/shared -I../../../platform/MCU/STM32F2xx/CMSIS/Include -I../../../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../../../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../../../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../../../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../../../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../../../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I. -MD -MP -MF ../../../build/target/user-part/platform-6-m/user-part.elf.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb ../../../build/target/user-part/platform-6-m/src/module_info.o ../../../build/target/user-part/platform-6-m/src/user_export.o ../../../build/target/user-part/platform-6-m/src/user_module.o ../../../build/target/user-part/platform-6-m/src/newlib_stubs.o --output ../../../build/target/user-part/platform-6-m/user-part.elf -Wl,--whole-archive ../../../hal/src/photon/lib/STM32F2xx_Peripheral_Libraries.a -Wl,--no-whole-archive --specs=nano.specs -lnosys -L../../../modules/photon/system-part2 -L../../../modules/photon/system-part1 -L. -T./linker.ld -Wl,--defsym,USER_FIRMWARE_IMAGE_SIZE=0x20000 -Wl,--defsym,USER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -Wl,-Map,../../../build/target/user-part/platform-6-m/user-part.map -L../../../build/target/user/platform-6-m/src/ -L../../../build/target/services-dynalib/arm/ -L../../../build/target/hal-dynalib/platform-6-m/ -L../../../build/target/system-dynalib/platform-6-m/ -L../../../build/target/rt-dynalib/platform-6-m/ -L../../../build/target/wiring/platform-6-m/ -L../../../build/target/communication-dynalib/platform-6-m/ -L../../../build/target/platform/platform-6-m/ -L../../../hal/src/photon/lib/ -Wl,--whole-archive -luser -lhal-dynalib -lservices-dynalib -lsystem-dynalib -lrt-dynalib -lwiring -lcommunication-dynalib -lplatform -Wl,--no-whole-archive -L../../../build/arm/linker -nostartfiles -Xlinker --gc-sections
Invoking: ARM GNU Create Flash Image
arm-none-eabi-objcopy -O binary ../../../build/target/user-part/platform-6-m/user-part.elf ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc
if [ -s ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc ]; then \
head -c $((`stat --print %s ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc` - 38)) ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc > ../../../build/target/user-part/platform-6-m/user-part.bin.no_crc && \
tail -c 38 ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc > ../../../build/target/user-part/platform-6-m/user-part.bin.crc_block && \
test "0102030405060708090a0b0c0d0e0f101112131415161718191a1b1c1d1e1f20280078563412" = `xxd -p -c 500 ../../../build/target/user-part/platform-6-m/user-part.bin.crc_block` && \
../../../build/bin/win32/sha256sum ../../../build/target/user-part/platform-6-m/user-part.bin.no_crc | cut -c 1-65 | xxd -r -p | dd bs=1 of=../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc seek=$((`stat --print %s ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc` - 38)) conv=notrunc && \
head -c $((`stat --print %s ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc` - 4)) ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc > ../../../build/target/user-part/platform-6-m/user-part.bin.no_crc && \
crc32 ../../../build/target/user-part/platform-6-m/user-part.bin.no_crc | cut -c 1-10 | xxd -r -p | dd bs=1 of=../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc seek=$((`stat --print %s ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc` - 4)) conv=notrunc ;\
fi
32+0 records in
32+0 records out
32 bytes (32 B) copied, 0.00122994 s, 26.0 kB/s
/usr/bin/sh: /cygdrive/c/Perl/bin/crc32: /usr/bin/perl: bad interpreter: Permission denied
0+0 records in
0+0 records out
0 bytes (0 B) copied, 0.000363784 s, 0.0 kB/s
[ ! -f ../../../build/target/user-part/platform-6-m/user-part.bin ] || rm ../../../build/target/user-part/platform-6-m/user-part.bin
mv ../../../build/target/user-part/platform-6-m/user-part.bin.pre_crc ../../../build/target/user-part/platform-6-m/user-part.bin
arm-none-eabi-objcopy -O ihex ../../../build/target/user-part/platform-6-m/user-part.elf ../../../build/target/user-part/platform-6-m/user-part.hex
arm-none-eabi-size --format=berkeley ../../../build/target/user-part/platform-6-m/user-part.elf
text data bss dec hex filename
4596 144 332 5072 13d0 ../../../build/target/user-part/platform-6-m/user-part.elf
arm-none-eabi-objdump -h -S ../../../build/target/user-part/platform-6-m/user-part.elf > ../../../build/target/user-part/platform-6-m/user-part.lst
make[1]: Leaving directory `C:/Particle/firmware/modules/photon/user-part'
BUILD SUCCESSFUL (total time: 6s)
Which shows success, although I can see this, which also suggests CRC:
0+0 records in
0+0 records out
mdma
July 22, 2015, 7:50pm
23
Yep, looks like crc is failing. I see it mentions cygwin in the path - I recommend installing MinGW and using the crc32 from there.
Dave
August 24, 2015, 8:29pm
24
Opened an issue for this here -> https://github.com/spark/firmware/issues/581
David
