Photon 2 and DS18B20 challenges
Hoping this is the appropriate forum to bring up this topic.
I am looking to migrate from the ElectricImp platform so I purchased a Photon 2 device to evaluate the Particle platform.
Once I received the Photon 2 I tried to bring up a DS18B20 based temperature monitor and got into trouble.
Browsing the Particle Community I learned that other folks are not able to migrate DS18B20 devices from the previous Photon to the newer Photon 2 because the available libraries are not Photon 2 compatible.
What is the roadmap to get over this hurdle:
  • is there a plan to update the 18B20 libraries?
  • is it possible still to purchase the older Photons?
  • any other options?
Thank you
It is not possible to implement the DS18B20 on RTL872x devices without additional hardware.
The recommended way is to use a DS2482 I2C to 1Wire bridge, as mentioned in the migration guide.
Particle does not have any Photon 1 or Argon devices left, and it's not likely that distributors or resellers have any left, but they could.
If you can redesign for a i2c (or spi) temperature sensor, that would be the best path forward.
