Hello looking for a suggested pattern to still receive an impact event on a tracker even if I have just published the location. There is a small chance a device could publish location then an impact event could occur but I may lose it. Is it possible to always publish on impact events?
You can set the “Maximum location update frequency (every n seconds)” to 0, which means that it will publish any time there is a trigger. Then in Motion, enable the High-G trigger.
Note that having the update frequency to 0 might cause you to publish quite a bit and use a lot of data operations.
