Passing an object to a function => Compiler error? [SOLVED]
I think the following code should compile
class MyClass
    public:
        int var;
void MyFunction(MyClass *p)
Yet get a compile error
objectparam.cpp:4:17: error: variable or field 'MyFunction' declared void
  void MyFunction(MyClass *p);
 objectparam.cpp:4:17: error: 'MyClass' was not declared in this scope
 objectparam.cpp:4:26: error: 'p' was not declared in this scope
Any ideas how to fix this?
Mark
I’ve edited your post to properly format the code. Please check out this post, so you know how to do this yourself in the future. Thanks in advance! ~Jordy
Hi @beharrell
The Spark preprocessor that lets you avoid certain requirements in C/C++ does not like classes in a sketch file. You can move your header and class to .h and .cpp files or you can turn the preprocessor off with this:
#pragma SPARK_NO_PREPROCESSOR
#include "application.h"
Since the preprocessor handles function prototypes and forward references for you, you might have some code reordering or other changes to make as well.
Thanks for the response.
Tried both suggested methods
the SPARK_NO_PREPROCESSOR method works for me
but moving the class into a separate header file fails
i.e.
The header file (TheClass.h)
#ifndef THECLASS_H
//#include "application.h"
class MyClass
    public:
        int var;
#endif
the ino file
 #include "TheClass.h"
void MyFunction(MyClass *p){
Still gives the same error.
Solved by placing function declaration into header file i.e.
#ifndef THECLASS_H
class MyClass
    public:
        int var;
#endif
Thanks for the help
Mark
