ParticleFtpClient - check client connection
I am using the ParticleFtpClient library with a Photon to access an FTP server. There is a lot of time lost in authentication so since the FTP server is under my control, is there a way to check first if the client is still connected? This way I can avoid having to reconnect …
BTW, I tried this but it did not work:
if (ftp.connected())
Is there something wrong?
I also plan on using this library so I’m interested in your question also.
Are you mainly uploading or downloading from the FTP server?
How large are the files normally?
How reliable are the transfers?
Hi @RWB,
I was just going to respond to my own post when I read yours.
I changed my server to FileZilla and now everything works.
As to your questions:
Uploading
Very small, < 30KB
Very reliable (but a bit time consuming). Not having to reconnect saves about 4 seconds on the Photon.
Good to know.
Have you tried this with a hosted FTP server vs an FTP server running from your computer?
Wondering if there are any differences?
No, I am hosting the FTP Server.
@ScruffR recommends (and I agree) that it may be better to run your own TCP server to avoid the FTP connection overhead.
Also, using an Electron as an FTP client is a lot slower …
