Particle.variable() with IP Address
Hello Particle Community!
I’m trying to bind a device’s IP address to a variable in the cloud, but the resulting value ends up weird.
Here’s my code:
    char ipString[16];
    server.begin();
    IPAddress ip = WiFi.localIP();
    sprintf(ipString, "%d.%d.%d.%d", ip[0], ip[1], ip[2], ip[3]);
    Particle.variable("ipAddress", ipString);
And here’s the data I get back from the API call:
{“cmd”:“VarReturn”,“name”:“ipAddress”,“result”:“�(\n\b”, …}
I’m not very acquainted with C so I’m not sure what’s going on. Any help would be greatly appreciated!
By the way, publishing ipString as an event works out fine and is completely readable but I want to be able to access the address as a variable instead of having to subscribe to an event stream.
Thanks =)
Your exposed base variable (ipString[]) needs to be global.
Thanks so much @ScruffR!
Thanks for the help!
