Particle Tools Changelog
January 18th 2021: Device OS v3.2.0
Note: This is a Release and may be used for production.
3.2.0
Highlights
  • acquireSerialXBuffer() API support for configuring custom buffer sizes for hardware UARTs (e.g. Serial1) #2375
  • [Boron / B SoM] Support for SARA R510 #2359 #2365
  • [Gen 3] BLE: extended advertisement support with Coded PHY #2331
  • [Argon / Tracker] Avoid power leakage through ESP32 ESPBOOT pin #2342
  • Fixes parsing of JSON strings with more than 127 tokens #2348
  • Reset scheduled module updates performed by the bootloader in case a second OTA update happens before they are applied (e.g. if System.disableReset() is used to postpone a pending device reset) #2346
  • Fix hardfault handler to SOS again #2381
  • [Gen 3] Fix LittleFS truncate causing file corruption #268 #2385
  • [Gen 3] HAL - Only skip modules that fail integrity check from module info #2387
... and other bugfixes and improvements!
:star2: Be sure to read the full collection of release notes Particle Device OS Updates Thread.
