Particle.subscribe unique device ID not returning correct values
I’m using the following command and the values returned are not correct when using the device ID :
Particle.subscribe(“Humidity”, myHandler1, “2d002…xx…3230”);
The values returned are somewhat random integers. Examples:
Time:1:52,
Soil Humidity1:29.00
Time:2:2,
Soil Humidity1:50.00
Time:2:22,
While using:
Particle.subscribe(“Humidity”, myHandler1, MY_DEVICES);
does return the correct value from the unique device (my only device with the event “Humidity”):
Time:9:56,
Soil Humidity1:55.82
Is my use in the 1st example correct or am I missing a parameter?
Seems ok… though you might want to post the handler code so that we can see what’s going on
Here is the relevant code. As I mentioned previously, when I use the MY_DEVICES parameter vs the device ID, the data is correct. When using MY_DEVICES, I need to have unique output variables for each subscription (which I am tying to avoid). I want to subscribe to the Humidity variable in a per device, per handler basis.
#include "stdlib.h"
#include "TimeAlarms/TimeAlarms.h"
#include "elapsedMillis/elapsedMillis.h"
//  Define names for the Digital pins On the Photon D0, D1
//  These data pins link to Relay board pins IN1, IN2
#define RELAY1  D0
#define RELAY2  D1
//Set the timer for the void loop function
elapsedMillis timeElapsed; //declare global if you don't want it reset every time loop runs
unsigned int interval = 3600000; //This is the delay in ms. 3,600,000=1hr
// Declare the variables
float totalPrecip;
float totalPrecipMin = 5.08; //Values are reported in mm, 5.08 is .2in.
float soil_humidity = 80; //This is the soil moisture minimum
int relay_duration = 420000;  //Duration in ms.  420,000=7mins
float humidity_a1 = 100; //Initially sets humidity at 100% so relays do not switch on when no value exists for humidity
float humidity_a2 = 100;
//Define the Handlers
void myHandler1(const char *event, const char *data)
humidity_a1 = atof (data);
void myHandler2(const char *event, const char *data)
humidity_a2 = atof (data);
  Time.zone(-8);
  // create the alarms
  Alarm.alarmRepeat(5,30,0, MorningAlarm);  // 5:30am every day
  // Listen for the hook response
  Particle.subscribe("hook-response/CLD_precipitation", gotWeatherData, MY_DEVICES);
// Initialize the Photon data pins for OUTPUT
  pinMode(RELAY1, OUTPUT);
  pinMode(RELAY2, OUTPUT);
  Particle.subscribe("Humidity", myHandler1, "123456789ABCDEF");
  Particle.subscribe("Humidity", myHandler2, "ABCDEF123456789");
  digitalWrite(RELAY1,HIGH);          // Turns Relay Off
  digitalWrite(RELAY2,HIGH);          // Turns Relay Off
  Serial.println("Hello");
void loop(){
  if (timeElapsed > interval)
  Serial.print("Time:");
  Serial.print(Time.hour());
  Serial.print(":");
  Serial.print(Time.minute());
  Serial.println(",");
  Serial.print("Soil Humidity1:");
  Serial.println(humidity_a1);
  Serial.print("Soil Humidity2:");
  Serial.println(humidity_a2);
  Serial.println("Requesting Precipitation!");
  Particle.publish("CLD_precipitation");
  timeElapsed = 0;
  Alarm.delay(1000);
When using the CLI: particle subscribe Humidity 123456789ABCDEF ,the correct data is returned as well.
Any help is appreciated. Thanks!
Just to try… can you use 2 unique event name like:
Particle.subscribe("Humidity1", myHandler1, "123456789ABCDEF");
Particle.subscribe("Humidity2", myHandler2, "ABCDEF123456789");
and see if the problem persists?
Does not work, although, the below works.
Particle.subscribe("Humidity1", myHandler1, MY_DEVICES);
Particle.subscribe("Humidity2", myHandler2, MY_DEVICES);
I am performing a copy/paste on the ID numbers, so there are not typos and when I run it in the CLI (particle subscribe Humidity 123456789ABCDEF), the correct values are returned. I guess a workaround is that I'll manage variables in my code and mini deployment, but I believe that is going to make overall device management much more difficult.
I think we should ping @Dave here and see if the deviceID subscribe endpoint is working in the cloud yet. I seem to recall this was delayed before and I don’t know the state now.
Could you also show the Particle.publish() commands the should trigger the subscriptions?
There is a still open issue
Here are the publish commands:
Sensor1:
Particle.publish(“Humidity1”, String(humidity), 60, PRIVATE);
Sensor2:
Particle.publish(“Humidity2”, String(humidity), 60, PRIVATE);
These are issued from two different devices (not two sensors on one Particle device), right?
As mentioned in the linked issue and in more detail in the closed issue #371 you could try to publish publicly (just to test) - it used to work (counter-intuitively) that way with 0.4.5 and I guess it hasn’t really changed since.
Hopefully it will be with 0.4.9 (0.4.8 seems to only be internal/develop).
Yes. Two different particle devices. I’ll try to publish publicly and I’ll let you know if that works. Thanks!
It appears to work when published publicly. Thanks!
Yup, as I thought - still no change :weary:, but we can still hope for 0.4.9+ :wink:
Get or get not, there is no hope.
The issue is milestoned for 0.4.9 (since 0.4.8 will not go public :wink: )
Hello,
So just to clarify that I understand this issue correctly; if I want to Particle.subscribe() to a unique device_id, I want to Particle.publish() that event as PUBLIC instead of PRIVATE ?
Thank you!
EDIT: Also, if I Particle.publish(“myvar”, myDat, PUBLIC) and subscribe to “myvar” on the same Photon, will I essentially be creating a recursive event, or will it ignore publish events coming from itself?
Basically, I have 2 photons that will be publishing a touch event with color data and subscribing to each others event - should I just use 2 seperate, unique “myvar” with different names or will the Photon ignore publish’s from it self?
This behaviour that you have to publish publicly to subsribe to a device ID is not intended and should get corrected.
About a possible “recursion”: If you intend to publish from a subscribe handler you should add some info about the origin to either even or data and check in the handler to prevent this situation.
