Particle setup on cli, automatic wifi
With larger batches like that, it might be more convenient to use `Particle serial wifi ‘ since it’s a lot faster, and doesn’t require you to switch wifi all the time. You could probably even write some sort of script for it :slight_smile:
@wesner0019: dug around some more, and found a script, which might be interesting :smile:
