I would try a delay after Particle.publish() - comment / uncomment to try the two different delays out below:
if(Particle.connected()) {
Particle.publish();
//delay(1000); // this will block for 1000ms allowing only ONE Particle.process()
// or
for(uint32_t _ms = millis(); millis() - _ms < 1000; Particle.process()); // many calls of Particle.process()
The rest of your code in loop() should be non-blocking. If you are using SYSTEM_MODE(MANUAL) you will need to place Particle.process() in your loop().
A 12 second delay is about what would be expected if the first publish packet was lost (no acknowledgement receive), or the ACK was lost. There’s a delay before retry, and three retries.
thank you @robc, may I know the point of the delay or call Particle.process() many times and how it may help? thanks for the library, I’d definitely checks it out!
If possible, please post your actual code. That will help in the discussion.
There is a rate limit on the number of calls of Particle.publish() statements. So, typically, while initially developing your code, make a 1 second delay after each statement to help you stay within the rate limit just in case your code calls many publish statements in a row. Here is more about this:
A delay(x000); statement can be considered blocking.
Your loop() routine iterates endlessly and every time it “loops” it calls Particle.process() once, UNLESS your using SYSTEM_MODE(MANUAL). In the commented out statement of the example I offered, using the For() statement which calls Particle.process() can be considered a non-blocking delay.
Anyway, based on this, not all use cases we need to add 1s delay in between publish. If the interval in between publish is long, we can skip that delay.
Instead of Particle.publish() I utilize publishQueue.publish() whenever possible. You will need to install the library, PublishQueueAsyncRK, to use it but the results are non-blocking. For example:
publishQueue.publish("xyz sensor", "does NOT exist", PRIVATE, WITH_ACK);
will not block while the “WITH_ACK” is dealt with. There is a link near the top of this thread for more info about the library.
