I was building a Internet connected Rattrap. It was supposed to publish “Rat Trapped” to the cloud once D6 pin goes low. It does get triggered but it publishes 4 times once triggered. Here is the code.
int triggerPin = D6;
bool messageSent = false;
pinMode(triggerPin, INPUT);
int trigger = digitalRead(triggerPin);
if(trigger == LOW && messageSent == false){
Particle.publish(“Rat Trapped”);
messageSent = true;
if(trigger == HIGH){
Most switches require debouncing - at the moment of contact or release it may switch back and forth between high and low several times. Since you got 4 timestamps in the same second, and there’s a maximum of 4 publishes per second, I’d guess that’s what you’re seeing.
There are a number of ways you could fix this; in your trap example instead of clearing after a single HIGH you might wait for, say 50 high loops before clearing messageSent.
Thanks for the help! I will try to implement this debouncing thing!
@rickkas7 I tried to implement debouncing but It's still publishing 4 events. May be it's an issue with my code. Here It is
int lbounce = 0;
int hbounce = 0;
int lowbounce;
int highbounce;
if(trigger == LOW){
lowbounce = lbounce++;
highbounce = hbounce++;
if(lowbounce >= 50 && messageSent == false){
Particle.publish("RatTrapped");
messageSent = true;
if(highbounce >= 50){
Please Help!
Your logic isn’t quite right; since low bounce and high bounce are never reset to zero, it’s not quite going to work. I was thinking something simpler like:
int highCount = 0;
Particle.publish("Rat Trapped");
messageSent = true;
highCount = 0;
if(trigger == HIGH && messageSent == true) {
if (highCount++ > 100) {
@rickkas7 Copied+Pasted+Flashed. Its still publishing 4 events.
Do you have an external pull-up resistor on your switch? If not, try changing pinMode(triggerPin, INPUT); to pinMode(triggerPin, INPUT_PULLUP); Also, try changing the test to 1000 from 100. I just ran a test on an actual Photon and it worked with those settings.
@rickkas7 No, I Haven’t attached any external PULLUP Resistor. Currently, This is my current Code
int highCount = 0;
messageSent = true;
highCount = 0;
if (highCount++ > 1000) {
Now, It’s NOT even publishing once…
The switch connects from D6 to ground (not 3.3V), right? If that’s not it, I’m stumped.
@rickkas7 Seems like I have to connect a External Pull-up. It’s working fine if I manually connect D6 from 3.3v to GND. Thanks for the help!
