Even with SYSTEM_THREAD(ENABLED), I notice that a particle.publish() within my loop() blocks the execution of application code if there is no WiFi connection. Is this normal?
To get around it I’m using:
if(WiFi.ready)
particle.publish()
It seems to work… comments?
Thanks.
That currently is the default behaviour, but should get addressed some time.
To ensure this doesn’t get lost, you could open a GitHub issue.
Actually you should check the cloud connection, not only WiFi
if (Particle.connected())
Particle.publish();
Thank you for the reply. I will change my code as well.
