Particle.process() quirks
Yes. While in manual mode, you are responsible for placing Particle.process() in your code. So far, you have had no trouble with your code. A one second blocking delay is not affecting your connection, yet.
The delay(1000) statement happens to call Particle.process() for you but, as you add new routines, may not call it often enough. A connection could break if not attended by Particle.process() often enough.
I had read about this a long time ago. Hope the following helps. Here is what I found today in the forum:
