PSA:
I have been struggling to get a semi-automated test stand working that writes a test firmware to the device, then runs a test procedure, then writes application firmware.
I am using particle serial flash to do this job, which relies on the P1 being in Listening mode. My test firmware starts out in listening mode and waits for a button press before starting the serial port, so that’s no problem-- that is, I can write firmware to it after any restart.
But what I found is that even with SYSTEM_THREAD(ENABLED), you MUST do a Particle.process() in your non-yielding code to make it work.
i.e. this works:
WiFi.on();
WiFi.setListenTimeout(0);
WiFi.listen();
bool ready = false;
while(!ready) {
//Serial.println("Waiting.. Press power button to start!");
if (PAHardware.isPowerButtonPressed()) ready = true;
delay(10);
Particle.process();
but this does not:
WiFi.on();
WiFi.listen();
bool ready = false;
while(!ready) {
// Print message once a second, test button every 1/10th
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
I had been under the impression that Particle.process() was a NOP in this system mode, and that seems not to be the case.
(Sorry for the weird messy code, but this was the precise change that made it work!)
