I’m developing a react native application that combines a Photon Particle.
By following the documentation of a Two legged auth; before configure a device I need to get a claim code.
curl -X POST \
https://api.particle.io/oauth/token \
-H 'Accept: application/json' \
-H 'Content-Type: application/x-www-form-urlencoded' \
-d 'grant_type=client_credentials&client_id=client_id&client_secret=clsecret&scope=customer%3Demail%40gmail.com'
When I do the request using CURL or even postman I got the desired results. But when I tried this using axios inside react native (iOS), I’m always getting the following error: Invalid or missing grant_type parameter.
The code below is my React Native code that is retrieving the data. And as you can see, I’m passing the grant_type.
costumerToken() {
const route = `${this.route}/oauth/token`;
const headers = {
"Accept": "application/json",
"Content-Type": "application/x-www-form-urlencoded"
const body = {
"grant_type": "client_credentials",
"client_id": this.clientId,
"client_secret": this.clientSecret,
"scope": `customer=${this.costumerEmail}`
console.log(route, headers, body);
return axios.post(route, body, {headers: headers})
.then(res => {
return Promise.resolve(res);
.catch(err => {
return Promise.reject(err.response);
What is wrong?
