Hi, I have noticed that Photon 2 tends to hang, even simply running the blink sketch or tinker. It hangs from time to time at any random level of breathing state - sometimes bright, sometimes dimm or off.
I have spent quite significant amount of time trying to find out why and I have discovered that this is due to I was using internal antenna. Hnaging happened more often to those photons that have had a weak wifi signal.
All in all - since I have switched from internal antenna to external one, it hangs no more, not even a single time (I have like 5 of them running 24/7 powered via USB).
Looks like the Photon P2 design has a flaw and is suffering some RF issues while using the internal antenna.
Are there any similar reports or plans to improve it?
I also wanted to create this thread to hint at what may help in case of such issues.
What version of Device OS are you running on the device?
The issues I have had were observed mainly under version 5.9.0.
I have tried some other versions, but they didn't change anything, so I returned to 5.9.0. I haven't tried 6.2.1 yet.
All the issues were gone once I switched to an external antenna.
The SOS when you have poor Wi-Fi signal strength is probably not fixed yet. See this thread:
