I’m having trouble keeping my devices online and reachable with a 3rd party SIM.
I’m currently using a 60sec Particle.publish which posts the battery voltage and the uptime.
I assumed perhaps incorrectly that this would be enough to keep the UDP session active, and therefore I wouldn’t need to use the Particle.keepAlive - the thinking was that I might as well post something useful rather than just have a keep alive.
Even with a 60sec publish the device still has device connected events appear every so often, so it’s definitely still going offline.
As a side note, when the device reboots, it occasionally does not register it’s particle functions with the particle cloud. so while I can see the events arriving it is basically unreachable.
My question is. - is it acceptable to use the Particle.publish rather than a Particle.keepAlive? It’s really frustrating when it doesn’t stay online.
Also I have a MQTT session running on the same device and this is rock solid. (it does drop out every now and then and it immediately reconnects without issue.
Marshall
