How can I use a Particle Function to return a String (instead of an integer)?
When using String as the return type, I am getting the following compile errors:
no matching function for call to 'CloudClass::_function(const char [8], String (*&)(String))
invalid conversion from 'String (*)(String)' to 'int (*)(String)' [-fpermissive]
The reason is because I need to find the value of multiple variables (separated by a comma) but do not want to find each value using a separate Particle variable.
There are several possibilities to solve your problem. The return from a function is a 32 bit integer, so you could combine values into a single int if they’re small enough or there aren’t too many of them. If that doesn’t work, you could certainly have a single variable (string) that’s a concatenation of your other variables, so you can get them all with a single Particle.variable. You could also publish a string that combines all the data. What works for you might depend on how you can pull apart the combined data on the receiving end.
"If that doesn’t work, you could certainly have a single variable (string) that’s a concatenation of your other variables, so you can get them all with a single Particle.variable. "
I’m sure there are several ways to do this. If you want to have named variables, you could create them, and a “master” string that would contain all the variable values. For instance, here’s an example with four variables,
Master would be your Particle.variable. Any place in your code where any of the four variables is set to a new value, you would need to call a function that updates the value of master,
void createParticleVariableString() {
snprintf(master, sizeof(master), "%s,%s,%s,%s", varA, varB, varC, varD);
This would give you a comma separated c-string of all your values.
You use %d for ints, %f for floats or doubles, %s for c-strings, etc. See here for snprintf() reference, and here for an explanation of the format specifiers.
