Hello
I am working on an application that allows either through the humidity level or manually (console or mobile phone) to control the speed of a three-speed fan. For this I used the particle.function. In order to avoid that more than one speed is activated in the manual function, I put a command to deactivate the other two speeds and it works (see attachment). It remains for me to understand how to send the status of the speeds off so that 0 appears on the console or on the mobile phone apps for the two speeds which are low(Lstato=Off and Hstato=Off).
Regards Valentino
In setup(), just above your Particle.function() statement, make two more statements to show the two values or status in the console or app. Something like this:
Thanks for the answer, probably I didn't express myself correctly, in manual mode I start with setting the speed Low (both in the console and on the app) near "f Lspeed appears 1 (ON)" now I change the fan speed and put Mspeed and as above in "f Mspeed 1 (ON)" appears, the fan runs at this speed while the Lspeed is zero but not on the display, see attached photo. I hope I have expressed myself correctly.
Regards Valentino
Hi Valentino,
I see what you are trying to accomplish now. Frankly, I do not know how to do it! But, I do have a different recommendation. I would use only one Particle.function() to command the fan manually and then one Particle.variable() to review/display the actual state of the fan.
I would try using an enum when controlling the possible states of the fan. Here is an example enum:
In logic, when humidity levels change or, manually, when you want to immediately affect the fan operation, make a change in the fan state variable by choosing from one of the four choices in the enum. Here is a particle variable & function example:
Particle.variable("present_fan_state", fanState); // value showing only one of enum values
Particle.function("change_fan_state", changeFanState); // routine changeFanState() called
Here is what your changeFanState() routine might look like:
int changeFanState(String command) { // command thru particle cloud to change global fan state
if (command.toInt() >= 0 && command.toInt() <= 3) { // allow only 1 of 4 possible states
if (g_fanState != command.toInt()) { // command is different from present global fan state
g_fanState = command.toInt(); // so, change the global fan state
// do some stuff
return 1;
} else {
return -89; // command same as present global fan state
} else {
return -99; // invalid command
} // END changeFanState function
Here is a routine example dealing with humidity:
void changeFanStateBasedOnHumidity() { // global humidity value controls global fan state
int changeFanState;
if (g_humidity >= 70.0) { // high speed
changeFanState = fan_High_Speed;
} else if (g_humidity >= 60.0) { // medium speed
changeFanState = fan_Medium_Speed;
} else if (g_humidity >= 50.0) { // low speed
changeFanState = fan_Low_Speed;
} else {// g_humidity < 50.0 turn off fan
changeFanState = fan_Off;
if (changeFanState != g_fanState) { // result is a different state from present global fan state
g_fanState = changeFanState; // so, change the global fan state oops! forgot this line in original post!
// do some stuff
} // END changeFanStateBasedOnHumidity
