:particle: :particle: Firmware 0.4.9 has shipped!! :particle: :particle:
FEATURES
ENHANCEMENTS
  • System.freeMemory() shows an accurate value for free memory rather than the highwater mark for the heap.
  • [threading] Entering listening mode does not block the system thread. #788
  • [threading] System times out waiting for unresponsive application when attempting to reset. #763
  • [threading] Particle.publish() doesn’t block when in listening mode. #761
  • [threading]. delay()/Particle.process() pumps application events.
  • Serial, Serial1, SPI and EEPROM global objects guaranteed to be initialized before use. (Prevents White breathing LED if Serial used in a global instance constructor.)
  • Software Timers have an option for one-shot timers, and support class member function callbacks.
BUGFIXES
  • RSA key generation would sometimes produce invalid keys. #779
  • Static IP configuration was not being used.
  • Interrupt on WKP with class method as an ISR #819
  • Memory leak configuring WiFi credentials via SoftAP (TCP/HTTP)
  • SPI DMA transfer callback invoked too early #791
  • Unset wiced_result_t for tcp clients in socket_send. #773
  • Update bootloader to support System.enterSafeMode(). #751
  • [threading] WiFi.listen(false) remains in listen mode. #743
  • Factory Reset doesn’t clear WiFi credentials until network.connect(). #736
  • Comparison between IPAddress objects does not always work. #715
  • P1 dfu-util 0.8 does not read/write from External Flash. #706
  • DFU errors writing to flash silently ignored. #813
  • [threading] heap allocation not thread-safe. #826
  • System crash when button interrupt occurs during i2c transmission. #709
  • [photon] 'analogWrite()` to DAC pins. #671
  • [photon] analogWrite() to DAC pins requires pinMode() each time. #662
  • [photon] System.sleep(pin,edge) doesn’t wake. #655
