Particle Dev has suddenly started failing to build for me. Even for previously good versions of my application. It reports: “build didn’t produce…” It appears I am overflowing the region ‘APP_FLASH’.
This exact application compiled fine on April 23rd.
I have seen this before, but never figured it out. It would just go away. Suggestions would be very welcome.
Doug
build didn't produce binary Error: Command failed: 32+0 records in
32+0 records out
32 bytes (32 B) copied, 7.6531e-05 s, 418 kB/s
4+0 records in
4+0 records out
4 bytes (4 B) copied, 0.0491178 s, 0.1 kB/s
In file included from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkApi.h:18:0,
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkApiParticle.h:14,
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkParticle.h:16,
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkDisplay.h:8,
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkDisplay.cpp:1:
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkProtocolDefs.h:88:0: warning: "htons" redefined [enabled by default]
#define htons(x) ( ((x)<<8) | (((x)>>8)&0xFF) )
In file included from ../hal/src/core/platform_headers.h:23:0,
from ./inc/application.h:32,
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/Measurement.h:3,
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/Display.h:8,
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkDisplay.h:7,
../platform/NET/CC3000/CC3000_Host_Driver/socket.h:188:0: note: this is the location of the previous definition
#define htons(A) ((((UINT32)(A) & 0xff00) >> 8) | \
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkProtocolDefs.h:89:0: warning: "htonl" redefined [enabled by default]
#define htonl(x) ( ((x)<<24 & 0xFF000000UL) | \
../platform/NET/CC3000/CC3000_Host_Driver/socket.h:180:0: note: this is the location of the previous definition
#define htonl(A) ((((UINT32)(A) & 0xff000000) >> 24) | \
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkProtocolDefs.h:93:0: warning: "ntohs" redefined [enabled by default]
#define ntohs(x) htons(x)
../platform/NET/CC3000/CC3000_Host_Driver/socket.h:192:0: note: this is the location of the previous definition
#define ntohs htons
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkProtocolDefs.h:94:0: warning: "ntohl" redefined [enabled by default]
#define ntohl(x) htonl(x)
../platform/NET/CC3000/CC3000_Host_Driver/socket.h:185:0: note: this is the location of the previous definition
#define ntohl htonl
In file included from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkParticle.h:16:0,
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/BlynkApiParticle.h:87:6: warning: #warning "analogInputToDigitalPin not defined => Named analog pins will not work" [-Wcpp]
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/NtpTime.cpp: In constructor 'NtpTime::NtpTime()':
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/NtpTime.cpp:33:33: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
init(UDPClient, "pool.ntp.org");
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/NtpTime.cpp: In constructor 'NtpTime::NtpTime(UDP*)':
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/NtpTime.cpp:37:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
init(_UDPClient, "pool.ntp.org");
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/WeatherSmallDisplay.cpp:4:
from /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/WeatherSmallDisplay.cpp:3:
#define ntohs htons
#define ntohl htonl
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/WeatherSmallDisplay.cpp: In function 'bool isDST(long unsigned int)':
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/WeatherSmallDisplay.cpp:226:27: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
int endMonth = 11; //November
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/WeatherSmallDisplay.cpp:233:25: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
// Return true if we are between the start and end of DST.
/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/WeatherSmallDisplay.cpp:219:7: warning: unused variable 'endSeconds' [-Wunused-variable]
/usr/local/gcc-arm-embedded-gcc-arm-none-eabi-4_8-2014q2-20140609-linux-tar-bz2/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld: /spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3.elf section `.data' will not fit in region `APP_FLASH'
/usr/local/gcc-arm-embedded-gcc-arm-none-eabi-4_8-2014q2-20140609-linux-tar-bz2/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld: region `APP_FLASH' overflowed by 592 bytes
make[1]: *** [/spark/compile_service/shared/workspace/0_core_28_2/firmware/main/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3/d98243a95fcf7ffb1ca7840019dae1a0bda85e65348fdb9a05e5016fade3.elf] Error 1
make: *** [main] Error 2
