Trying “particle serial monitor” getting this:
Please reinstall the CLI again using npm install -g particle-cli
Cannot read property 'list' of undefined
Caught Interrupt. Cleaning up.
Then trying that I get this:
npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/particle-cli
npm ERR! path /usr/local/lib/node_modules/particle-cli
npm ERR! code EACCES
npm ERR! errno -13
npm ERR! syscall access
npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/particle-cli'
npm ERR! { Error: EACCES: permission denied, access '/usr/local/lib/node_modules/particle-cli'
npm ERR! stack: 'Error: EACCES: permission denied, access \'/usr/local/lib/node_modules/particle-cli\'',
npm ERR! errno: -13,
npm ERR! code: 'EACCES',
npm ERR! syscall: 'access',
npm ERR! path: '/usr/local/lib/node_modules/particle-cli' }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! A complete log of this run can be found in:
npm ERR! /Users/myuser/.npm/_logs/2018-04-04T22_01_45_988Z-debug.log
