P2 BLE WiFi Setup Manager - Warnings
Using an adapted BLEWiFiSetupManager library I have added some further commands including one to clear credentials and disconnect from WiFi/Cloud. P2 Device OS 6.3.3
If I clear credentials I am seeing some warnings as follows:
[net.rltkncp] WARN: NCP connection state event ignored, netif not up
[ncp.rltk.client] WARN: Disconnect linkError=00000000 reason=0000:
Is this anything I should be concerned about, the process seems to work fine.
That’s normal. The interface can’t be brought up because there are no credentials.
