I’ve created an Oauth Client token at the owner level of the console, and have a product. Then when I try and add a device via the REST API to that product, I get a permission denied. It only works if I then create an Oauth Client token at the product level and authenticate against that to add a device to that product/
Is this correct behaviour? If so is it expected that you have a seperate Oauth for each product and have to keep track of each token to then be able to add a device to that product?
