Overkill spark light switch
If it’s the same chip, it shouldn’t matter who put the board together, other than different connections maybe. I personally use a board from aliexpress (China~ish?), and it works nicely.
As for the code I’ve used, this should be it: (@Maarten)
#include "mpr121.h"
#define ON 1
#define OFF 0
// Global Constants
int TOU_THRESH =	0x06;
int REL_THRESH =	0x0A;
int irqpin  = D5;  // Digital 2
boolean touchStates[12]; //to keep track of the previous touch states
void setup(){
    pinMode(irqpin, INPUT);
    pinMode(red, OUTPUT);
    pinMode(green, OUTPUT);
    pinMode(blue, OUTPUT);
    digitalWrite(irqpin, HIGH); //enable pullup resistor
    Wire.begin();
    mpr121_setup();
    RGB.control(true);
        RGB.color(255,0,0);
        delay(200);
        RGB.color(0,0,0);
        delay(200);
        RGB.color(0,0,255);
        delay(200);
        RGB.control(false);
void loop(){
  readTouchInputs();
void readTouchInputs(){
    if(!checkInterrupt()){
        //read the touch state from the MPR121
        Wire.requestFrom(0x5A,2);
        byte LSB = Wire.read();
        byte MSB = Wire.read();
        uint16_t touched = ((MSB << 8) | LSB); //16bits that make up the touch states
        for (int i=0; i < 12; i++){  // Check what electrodes were pressed
            if(touched & (1<<i)){
                if(touchStates[i] == 0){
                    //pin i was just touched
                    Serial.print("pin ");
                    Serial.print(i);
                    Serial.println(" was just touched");
                    switch (i) {
                        case 0:                 //RED
                            RGB.control(true);
                            RGB.color(255,0,0);
                            delay(100);
                            RGB.control(false);
                        break;
                        case 3:                 // GREEN
                            RGB.control(true);
                            RGB.color(0,255,0);
                            delay(100);
                            RGB.control(false);
                        break;
                        case 6:                 //BLUE
                            RGB.control(true);
                            RGB.color(0,0,255);
                            delay(100);
                            RGB.control(false);
                        break;
                        case 8:                 //OFF
                            RGB.control(true);
                            RGB.color(0,0,0);
                            delay(100);
                            RGB.control(false);
                        break;
                        case 11:                //WHITE
                            RGB.control(true);
                            RGB.color(255,255,255);
                            delay(100);
                            RGB.control(false);
                        break;
                else if(touchStates[i] == 1){
                    //pin i is still being touched
            touchStates[i] = 1;
            else{
                    Serial.print(i);
                    Serial.println(" is no longer being touched");
                    //pin i is no longer being touched
            touchStates[i] = 0;
void mpr121_setup(void){
  set_register(0x5A, ELE_CFG, 0x00);
  // Section A - Controls filtering when data is > baseline.
  set_register(0x5A, MHD_R, 0x01);
  set_register(0x5A, NHD_R, 0x01);
  set_register(0x5A, NCL_R, 0x00);
  set_register(0x5A, FDL_R, 0x00);
  // Section B - Controls filtering when data is < baseline.
  set_register(0x5A, MHD_F, 0x01);
  set_register(0x5A, NHD_F, 0x01);
  set_register(0x5A, NCL_F, 0xFF);
  set_register(0x5A, FDL_F, 0x02);
  // Section C - Sets touch and release thresholds for each electrode
  set_register(0x5A, ELE0_T, TOU_THRESH);
  set_register(0x5A, ELE0_R, REL_THRESH);
  set_register(0x5A, ELE1_T, TOU_THRESH);
  set_register(0x5A, ELE1_R, REL_THRESH);
  set_register(0x5A, ELE2_T, TOU_THRESH);
  set_register(0x5A, ELE2_R, REL_THRESH);
  set_register(0x5A, ELE3_T, TOU_THRESH);
  set_register(0x5A, ELE3_R, REL_THRESH);
  set_register(0x5A, ELE4_T, TOU_THRESH);
  set_register(0x5A, ELE4_R, REL_THRESH);
  set_register(0x5A, ELE5_T, TOU_THRESH);
  set_register(0x5A, ELE5_R, REL_THRESH);
  set_register(0x5A, ELE6_T, TOU_THRESH);
  set_register(0x5A, ELE6_R, REL_THRESH);
  set_register(0x5A, ELE7_T, TOU_THRESH);
  set_register(0x5A, ELE7_R, REL_THRESH);
  set_register(0x5A, ELE8_T, TOU_THRESH);
  set_register(0x5A, ELE8_R, REL_THRESH);
  set_register(0x5A, ELE9_T, TOU_THRESH);
  set_register(0x5A, ELE9_R, REL_THRESH);
  set_register(0x5A, ELE10_T, TOU_THRESH);
  set_register(0x5A, ELE10_R, REL_THRESH);
  set_register(0x5A, ELE11_T, TOU_THRESH);
  set_register(0x5A, ELE11_R, REL_THRESH);
  // Section D
  // Set the Filter Configuration
  // Set ESI2
  set_register(0x5A, FIL_CFG, 0x04);
  // Section E
  // Electrode Configuration
  // Set ELE_CFG to 0x00 to return to standby mode
  set_register(0x5A, ELE_CFG, 0x0C);  // Enables all 12 Electrodes
  // Section F
  // Enable Auto Config and auto Reconfig
  /*set_register(0x5A, ATO_CFG0, 0x0B);
  set_register(0x5A, ATO_CFGU, 0xC9);  // USL = (Vdd-0.7)/vdd*256 = 0xC9 @3.3V   set_register(0x5A, ATO_CFGL, 0x82);  // LSL = 0.65*USL = 0x82 @3.3V
  set_register(0x5A, ATO_CFGT, 0xB5);*/  // Target = 0.9*USL = 0xB5 @3.3V
boolean checkInterrupt(void){
  return digitalRead(irqpin);
void set_register(int address, unsigned char r, unsigned char v){
    Wire.beginTransmission(address);
    Wire.write(r);
    Wire.write(v);
    Wire.endTransmission();
Call this file mrp121.h:
#include "application.h"
    MPR121.h
	April 8, 2010
	by: Jim Lindblom
// MPR121 Register Defines
#define MHD_R	0x2B
#define NHD_R	0x2C
#define	NCL_R 	0x2D
#define	FDL_R	0x2E
#define	MHD_F	0x2F
#define	NHD_F	0x30
#define	NCL_F	0x31
#define	FDL_F	0x32
#define	ELE0_T	0x41
#define	ELE0_R	0x42
#define	ELE1_T	0x43
#define	ELE1_R	0x44
#define	ELE2_T	0x45
#define	ELE2_R	0x46
#define	ELE3_T	0x47
#define	ELE3_R	0x48
#define	ELE4_T	0x49
#define	ELE4_R	0x4A
#define	ELE5_T	0x4B
#define	ELE5_R	0x4C
#define	ELE6_T	0x4D
#define	ELE6_R	0x4E
#define	ELE7_T	0x4F
#define	ELE7_R	0x50
#define	ELE8_T	0x51
#define	ELE8_R	0x52
#define	ELE9_T	0x53
#define	ELE9_R	0x54
#define	ELE10_T	0x55
#define	ELE10_R	0x56
#define	ELE11_T	0x57
#define	ELE11_R	0x58
#define	FIL_CFG	0x5D
#define	ELE_CFG	0x5E
#define GPIO_CTRL0	0x73
#define	GPIO_CTRL1	0x74
#define GPIO_DATA	0x75
#define	GPIO_DIR	0x76
#define	GPIO_EN		0x77
#define	GPIO_SET	0x78
#define	GPIO_CLEAR	0x79
#define	GPIO_TOGGLE	0x7A
#define	ATO_CFG0	0x7B
#define	ATO_CFGU	0x7D
#define	ATO_CFGL	0x7E
#define	ATO_CFGT	0x7F
// Global Constants
//#define TOU_THRESH	0x06
//#define	REL_THRESH	0x0A
It worked for me, so give it a try :smile:
Cool i’ll order a cpl off ebay and try them out.
Thanks :smile:
