I have been working on a program that acts as an alarm clock which then opens my blinds. It seems like my core is running out of heap memory (According to the red flashes). Here is my code:
//declare variables for the motor pins
int turnD = D3; // turn DOWN
int turnU = D2; // Turn UP
int sensor = D6; // Hall Effect sensor input
bool isUp = false; // If up or not
int upcounter = 0;
int maxSteps = 1980;
bool partWayDownGoUp = false;
bool partWayGoDown = false;
int downTime = 1980;
String alarmTime = "";
String currentTime = "";
bool alarmEnabled = true;
String PassCommand = "";
String semi = ":";
String AM = " AM";
String PM = " PM";
// setup function to act on Spark API calls
Spark.function("Blind", BlindControl);
Spark.function("SetTime", setTimer);
Spark.function("isTimerEnabled", checkTimerState);
//declare the motor pins as outputs
pinMode(sensor, INPUT);
pinMode(turnU, OUTPUT);
pinMode(turnD, OUTPUT);
digitalWrite(turnU, HIGH);
digitalWrite(turnD, HIGH);
setBlindsUp();
void loop(){
getCurrentTime();
if(alarmTime.equals(currentTime)){
PassCommand = "Open";
BlindControl(PassCommand);
delay(300);
int BlindControl(String command){
if (command=="Open") {
while(isUp == false){
goUp();
Spark.process();
delay(100);
if(command =="Close"){
partWayGoDown = true;
break;
if(partWayGoDown == true){
goDown();
if (command=="Close" && isUp == true) {
goDown();
return 1;
int setTimer(String alarmSetTime){
alarmTime = alarmSetTime;
return 1;
int checkTimerState(String state){
if(state == "On"){
else if(state == "Off"){
alarmEnabled = false;
else{
return 1;
void goUp(){
digitalWrite(turnU, LOW);
isUp = checkPosition();
delay(100);
upcounter += 100;
void goDown(){//find out why this is fireing twice
digitalWrite(turnD, LOW);
if(partWayGoDown = true){
downTime = 198000 - upcounter;
for (int i = 0; i < 4; i++){
delay(downTime/4);
isUp = false;
downTime = 198000;
bool checkPosition(){
bool isUpOrNot = false;
if(digitalRead(sensor) == LOW){
isUpOrNot = true;
else if(digitalRead(sensor) == HIGH){
isUpOrNot = false;
return isUpOrNot;
void setBlindsUp(){
while(digitalRead(sensor) == HIGH){
isUp = true;
void getCurrentTime(){
**currentTime = "";**
int unixTime = Time.now(); //Returns Unix Time (Seconds)
int hour = Time.hour(unixTime);
String hourSTR = String(hour);
int min = Time.minute(unixTime);
String minSTR = String(min);
int sec = Time.second(unixTime);
String secSTR = String(sec);
bool isAm = Time.isAM();
if(isAm == true){
currentTime.concat(hourSTR);
currentTime.concat(semi);
currentTime.concat(minSTR);
currentTime.concat(secSTR);
currentTime.concat(AM);
else{
currentTime.concat(PM);
