Original Core code and web page no longer working
Back in the day when the was spark, I built a 4 channel doser for my aquarium using the spark core. A gentleman on here wrote the code for me so I could control it via a webpage as well. The unit has been running without issue for a long time, but today I went in to make an adjustment and the refresh command on the webpage no longer works. I went into the code to make sure the ID and token were still correct and they were. When I go to the build site it shows its connected, so I know its still on my network, and it allows me to flash the unit as well. When I try to access via my phone I can’t access it either.
Would someone mind taking a look at the code along with the html and see if I’m missing something? I’m sure some of this code could use some updating.
Core Code
#include "SparkTime.h"
UDP UDPClient;
SparkTime rtc;
int relayPin[4] = {D0,D1,D2,D3};
//By relays number
bool    isSet[4] = {false,false,false,false};
uint8_t startHours[4]   = {0,0,0,0};
uint8_t startMinutes[4] = {0,0,0,0};
uint8_t startSeconds[4] = {0,0,0,0};
unsigned int duration[4] = {0,0,0,0};
unsigned long stopTime[4] = {0,0,0,0};
#define NCHARS 32
char relayStr[4][NCHARS];
   for(int relay=0;relay<4;relay++) {
       pinMode(relayPin[relay], OUTPUT);
       digitalWrite(relayPin[relay], LOW);
   Spark.function("setRelay1", setRelay1);
   Spark.function("setRelay2", setRelay2);
   Spark.function("setRelay3", setRelay3);
   Spark.function("setRelay4", setRelay4);
   Spark.variable("getRelay1", relayStr[0], STRING);
   Spark.variable("getRelay2", relayStr[1], STRING);
   Spark.variable("getRelay3", relayStr[2], STRING);
   Spark.variable("getRelay4", relayStr[3], STRING);
rtc.begin(&UDPClient, "pool.ntp.org");
rtc.setTimeZone(-5); // gmt offset
rtc.setUseDST(true);
unsigned long currentTime = rtc.now();
    if (TRUE==isSet[relay]) {
        if (rtc.hour(currentTime)==startHours[relay] &&
            rtc.minute(currentTime)==startMinutes[relay] &&
            rtc.second(currentTime)==startSeconds[relay]) {
                digitalWrite(relayPin[relay],HIGH);
                stopTime[relay] = currentTime + duration[relay];
            } // start time
    } // is set
    if (currentTime >= stopTime[relay]) {
        digitalWrite(relayPin[relay],LOW);
delay(100);
// Parse the format: 08:56:05*6000 or 18:59:00*10
//  hh:mm:ss*duration
int parseTimeDuration(String command, int relay) {
    char copyStr[33];
    command.toCharArray(copyStr,33);
    char *p = strtok(copyStr, ":");
    startHours[relay]   = (uint8_t)atoi(p);
    p = strtok(NULL,":");
    startMinutes[relay] = (uint8_t)atoi(p);
    startSeconds[relay] = (uint8_t)atoi(p);
    p += 3;
    duration[relay]     = atoi(p);
    isSet[relay] = true;
    sprintf(relayStr[relay], "%02d:%02d:%02d*%d",startHours[relay],startMinutes[relay],startSeconds[relay],duration[relay]);
    return 1;
int setRelay1(String command) {
    return parseTimeDuration(command, 0);
int setRelay2(String command) {
    return parseTimeDuration(command, 1);
int setRelay3(String command) {
    return parseTimeDuration(command, 2);
int setRelay4(String command) {
    return parseTimeDuration(command, 3);
HTML Code
<!DOCTYPE HTML>
<html>
  <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.3.2/jquery.min.js" type="text/javascript" charset="utf-8">  </script>
<body>
  <P>Alkalinity: Current setting <span id="relay1">unknown</span>
    <button id="getR1" onclick="getRelay(1)">Refresh</button>
    &nbsp;&nbsp;&nbsp;&nbsp;New setting
    <select id="relay1hours">
    </select> :
    <select id="relay1minutes">
    </select>
    Duration
    <input type="text" id="relay1duration" value="10">  seconds
    <button id="setR1" onclick="setRelay(1)">Set</button>
  <P>Calcium: Current setting <span id="relay2">unknown</span>
    <button id="getR2" onclick="getRelay(2)">Refresh</button>
    <select id="relay2hours">
    </select> :
    <select id="relay2minutes">
    </select>
    Duration
    <input type="text" id="relay2duration" value="10">  seconds
    <button id="setR2" onclick="setRelay(2)">Set</button>
  <P>Magnesium: Current setting <span id="relay3">unknown</span>
    <button id="getR3" onclick="getRelay(3)">Refresh</button>
    <select id="relay3hours">
    </select> :
    <select id="relay3minutes">
    </select>
    Duration
    <input type="text" id="relay3duration" value="10">  seconds
    <button id="setR3" onclick="setRelay(3)">Set</button>
  <P>Relay 4: Current setting <span id="relay4">unknown</span>
    <button id="getR4" onclick="getRelay(4)">Refresh</button>
    <select id="relay4hours">
    </select> :
    <select id="relay4minutes">
    </select>
    Duration
    <input type="text" id="relay4duration" value="10">  seconds
    <button id="setR4" onclick="setRelay(4)">Set</button>
    <script type="text/javascript">
    for(i=0;i<24;i++) {
              for(relay=1;relay<5;relay++) {
                           var rh = document.getElementById("relay"+relay.toString()+"hours");
                           var opt = document.createElement("OPTION");
                           opt.setAttribute("value", i.toString() );
                           var nd  = document.createTextNode(i.toString());
                           opt.appendChild(nd);
                           rh.appendChild(opt);
    for(i=0;i<60;i++) {
                           var rm = document.getElementById("relay"+relay.toString()+"minutes");
                           rm.appendChild(opt);
      var deviceID    = "xxxxx";
      var accessToken = "xxxxx";
      var setFunc = "setRelay";
      var getFunc = "getRelay";
      function getRelay(relay) {
         requestURL = "https://api.particle.io/v1/devices/" + deviceID + "/" + getFunc + relay.toString() + "/?access_token=" + accessToken;
             $.getJSON(requestURL, function(json) {
                 document.getElementById("relay"+relay.toString() ).innerHTML = json.result;
      function setRelay(relay) {
        var newValue = document.getElementById("relay"+relay+"hours").value   + ":" +
                       document.getElementById("relay"+relay+"minutes").value + ":" +
        "00" + "*" +
                       document.getElementById("relay"+relay+"duration").value;
    var requestURL = "https://api.particle.io/v1/devices/" +deviceID + "/" + setFunc + relay + "/";
        $.post( requestURL, { params: newValue, access_token: accessToken });
    </script>
</body>
</html>
Resolved…had to completely reset and reprogram the core.
Can check if your firmware still does what it should with one of these test pages?
http://jordymoors.nl/interface
http://suda.github.io/particle-web-interface
OK, good to hear :+1:
