I am facing this problem with the spark core as well as with the arduino (with CC3000). I am running a MQTT client based on the library from knolleary. However, how do I know the RAM usage in my program?
This is because, code compiles and uploads successfully, but it does a publish and reboots. If I cut down a section of the code, it works fine.
So am I running out of RAM, or the MQTT client is not able to handle the payload., or a problem with CC3000.??
PS: My code receives 16 bytes of data via serial port, 8 bytes gives me two temperature parameters, each bit of 3 bytes gives me specific alarms, rest are ignored. I converted each of them into one meaningful string and published that via MQTT.
How are you compiling your code?
Usually you get a mem summary from the compiler - even the WebIDE (aka Sparkulator) does give you this info, when you click on “(i)” at the bottom of the screen after you compile.
Unfortunately this symbol disappears after some seconds and is not at all displayed if you recompile unchanged code.
Otherwise you might see something like
Output of arm-none-eabi-size:
text data bss dec hex
76448 1332 11892 89672 15
In a nutshell:
Flash used 77780 / 110592 70.3 %
RAM used 13224 / 20480 64.6 %
