OLED 4pin I2C (GND VDD SCK SDA) with Photon [SOLVED]
Hi @steb
I don’t see any pull-up resistors in your photo. If the display board does not have its own pull-ups, you need to add them. A pair 4.7k ohm to 3.3V for each line is the traditional value but if you don’t have that exact value, anything from 1k to 10k will work.
