OLED 240x240 connect to Photon 2
Hi together,
I don't get any information on the display. Am I using the wrong connections?
I don't want to use the Boron404X but Photon 2.
Here is the link to the project.
I would be very happy about help.
Andre, welcome to the community.
For us to help you we would need to firstly see a picture of the components and how you have connected them.
Using a Photon2 in the place of the Boron should not be a problem, however, you will need to adapt the sketch and use the correct pins on the Photon2.
Hi armor, thanks for your help.
Sorry, I forgot to share this.
I took the pins from Baron except for A5 and A4 and changed them accordingly in the sketch. Unfortunately without success.
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <Orbitron_Medium_40.h>
#include <Orbitron_Bold_20.h>
#include <Roboto_Condensed_Light_Italic_24.h>
#include <SHT31.h>
#include <weather_icons.h>
//SYSTEM_MODE(MANUAL);
//SYSTEM_THREAD(ENABLED);
//SerialLogHandler logHandler(LOG_LEVEL_TRACE);
//RGB565 custom colors
#define COLOR_PINK 0xf816
#define COLOR_LIME 0x87e0
#define COLOR_PEACH 0xfd89
  Pin assignment
  Display   Boron
  SDA       MOSI
  SCL       SCK
  RES       A5
  DC        A4
#define TFT_CS  -1  // The display I'm using does not have a CS pin, if yours does, assign a pin to it here
#define TFT_SDA MO
#define TFT_SCL SCK
#define TFT_RST S3
#define TFT_DC A5
#define LED_BLUE  D7
#define LED_RED A0
// For 1.14", 1.3", 1.54", 1.69", and 2.0" TFT with ST7789:
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
SHT31 sht31 = SHT31();
//If you are using the Photon 2, please comment out the following since Photon 2 does not have a fuel gauge
FuelGauge fuel;
char num = 0;
char number[8];
const float Pi = 3.14159265359;
GFXcanvas16 timeCanvas(240, 110);
GFXcanvas16 temperatureCanvas(240, 40);
String todayHigh, todayLow, dayoneHigh, dayoneLow, daytwoHigh, daytwoLow, daythreeHigh, daythreeLow;
String todayForecast, dayoneForecast, daytwoForecast, daythreeForecast;
unsigned long previousMillis = 0;  // will store last time LED was updated
// constants won't change:
const long interval = 1000;  // milliiseconds
const long pubinterval = 600; //interval at which to publish in seconds. this is done by counting number of intervals
unsigned long intervalcount = 0;
  //Subscribe to the Particle webhook response
  Particle.subscribe("hook-response/get_night_weather", getNightWeather);
  Particle.subscribe("hook-response/get_day_weather", getDayWeather);
  Particle.subscribe("hook-response/get_suntime", getSunriseSunset);
  //set time zone to pacific standard time
  Time.zone(-7);
  pinMode(LED_RED, OUTPUT);
  pinMode(LED_BLUE, OUTPUT);
  //enable power to the sht31 sensor
  //I've connected the power pin of the SHT31 to D3 but you can directly connect it to 3.3V
  pinMode(D3, OUTPUT);
  digitalWrite(D3, HIGH);
  //remember to modify SPI setting as necessary for your MCU board in Adafruit_ST77xx.cpp
  tft.init(240, 240, SPI_MODE3);
  tft.setRotation(2);
  tft.fillScreen(ST77XX_BLACK);
  sht31.begin();
  // draw the static icons
  tft.drawRGBBitmap(15, 135, sunrise, 40, 31);
  tft.drawRGBBitmap(85, 135, sunset, 40, 31);
  tft.drawRGBBitmap(160, 128, isro, 68, 66);
  // draw the horizontal console dividing lines
  tft.drawLine(0, 120, 240, 120, 0x8c71); //gray
  tft.drawLine(0, 199, 240, 199, 0x8c71); //gray
  // display the time and temperature and then update it regularly in the loop function
  drawTimeConsole();
  drawTemperatureConsole();
  String data = String(10); //dummy data
  // publish to trigger the webhooks
  Particle.publish("get_night_weather", data, PRIVATE);
  Particle.publish("get_day_weather", data, PRIVATE);
  Particle.publish("get_suntime", data, PRIVATE);
void loop(void)
  unsigned long currentMillis = millis();
  if (currentMillis - previousMillis >= interval)
    previousMillis = currentMillis;
    drawTimeConsole();
    ledBlink();
    intervalcount++;
  if (intervalcount > pubinterval)
    intervalcount = 0;
//The webhook response data will contain the sunrise and sunset time together as a string
void getSunriseSunset(const char *event, const char *data)
  tft.setTextColor(ST77XX_YELLOW, ST77XX_BLACK);
  tft.setFont();
  tft.setTextSize(2);
  tft.setCursor(5, 175);
  tft.print(data);
String numtoWeekday(int num)
  switch (num)
    case 1:
      return ("SUN");
    case 2:
      return ("MON");
    case 3:
      return ("TUE");
    case 4:
      return ("WED");
    case 5:
      return ("THU");
    case 6:
      return ("FRI");
    case 7:
      return ("SAT");
  return "NULL";
void drawTimeConsole(void)
  uint8_t hour = Time.hourFormat12();
  uint8_t minute = Time.minute();
  uint8_t second = Time.second();
  uint8_t weekday = Time.weekday();
  uint8_t day = Time.day();
  uint16_t year = Time.year();
  uint8_t month = Time.month();
  char timestring[10];
  timeCanvas.fillScreen(ST77XX_BLACK);
  timeCanvas.setFont(&Roboto_Condensed_Light_Italic_24);
  timeCanvas.setTextSize(1);
  timeCanvas.setTextColor(ST77XX_CYAN);
  timeCanvas.setCursor(0, 30);
  //timeCanvas.print("WED,19 APR,2023"); //sample string for testing
  timeCanvas.print(numtoWeekday(weekday));
  timeCanvas.print(",");
  switch (month)
    case 1:
      timeCanvas.print("JAN ");
      break;
    case 2:
      timeCanvas.print("FEB ");
      break;
    case 3:
      timeCanvas.print("MAR ");
      break;
    case 4:
      timeCanvas.print("APR ");
      break;
    case 5:
      timeCanvas.print("MAY ");
      break;
    case 6:
      timeCanvas.print("JUN ");
      break;
    case 7:
      timeCanvas.print("JUL ");
      break;
    case 8:
      timeCanvas.print("AUG ");
      break;
    case 9:
      timeCanvas.print("SEPT ");
      break;
    case 10:
      timeCanvas.print("OCT ");
      break;
    case 11:
      timeCanvas.print("NOV ");
      break;
    case 12:
      timeCanvas.print("DEC ");
      break;
  timeCanvas.print(day);
  timeCanvas.print(year);
  timeCanvas.setFont();
  timeCanvas.setCursor(205, 14);
  timeCanvas.fillRect(210, 0, 25, 10, ST77XX_BLUE);
  timeCanvas.fillRect(207, 3, 3, 4, ST77XX_BLUE);
  timeCanvas.setTextColor(ST77XX_WHITE);
  timeCanvas.print(fuel.getVCell()); timeCanvas.print("V");
  timeCanvas.setFont(&Orbitron_Medium_40);
  timeCanvas.setTextColor(ST77XX_GREEN);
  timeCanvas.setCursor(0, 75);
  sprintf(timestring, "%02d:%02d ", hour, minute);
  //sprintf(timestring, "%02d:%02d ", 2, 2); //test string that is the widest when displayed
  timeCanvas.print(timestring);
  //calculate the width of the time string so that you can appent the AM/PM at the end of it
  //this is required because the font width is not the same for all digits
  int16_t  x1, y1;
  uint16_t w, h;
  timeCanvas.getTextBounds(timestring, 0, 75, &x1, &y1, &w, &h);
  timeCanvas.setFont(&Orbitron_Bold_20);
  timeCanvas.setTextColor(0xe469);//orange
  timeCanvas.setCursor(w, 60);
  if (Time.isPM())  timeCanvas.print(" PM");
  else  timeCanvas.print(" AM");
  timeCanvas.setTextColor(COLOR_PINK);
  timeCanvas.setCursor(0, 110);
  timeCanvas.print("SAN FRANCISCO");
  drawWeatherBitmap(192, 45, todayForecast);
  timeCanvas.setTextSize(2);
  if (todayHigh == "  ")
    timeCanvas.setCursor(205, 95);
    timeCanvas.print(todayLow);
  else
    timeCanvas.setCursor(180, 95);
    timeCanvas.print(todayHigh); timeCanvas.print("|"); timeCanvas.print(todayLow);
  tft.drawRGBBitmap(0, 0, timeCanvas.getBuffer(), timeCanvas.width(), timeCanvas.height());
void drawTemperatureConsole(void)
  float temp = ((sht31.getTemperature()) * 1.8) + 32;
  float hum = sht31.getHumidity();
  temperatureCanvas.fillScreen(ST77XX_BLACK);
  temperatureCanvas.drawRGBBitmap(5, 10, thermometer, 15, 30);
  temperatureCanvas.setTextSize(1);
  temperatureCanvas.setFont(&Roboto_Condensed_Light_Italic_24);
  temperatureCanvas.setTextColor(ST77XX_WHITE, ST77XX_BLACK);
  temperatureCanvas.setCursor(30, 30);
  temperatureCanvas.print(temp); temperatureCanvas.print("F");
  temperatureCanvas.setCursor(140, 30);
  temperatureCanvas.print(hum); temperatureCanvas.print("%rH");
  tft.drawRGBBitmap(0, 200, temperatureCanvas.getBuffer(), temperatureCanvas.width(), temperatureCanvas.height());
void getNightWeather(const char *event, const char *night_data)
  int index0, index1, index2, index3, index4, index6, index5, index7, index8, index9, index10, index11, index12;
  String name;
  String weatherString = String(night_data);
  Serial.println(night_data);
  index0 = weatherString.indexOf('~');
  name = weatherString.substring(0, index0);
  Serial.println(name);
  if (name == "Tonight")
    todayHigh = "  ";
    index1 = weatherString.indexOf('~', index0 + 1);
    todayLow = weatherString.substring(index0 + 1, index1);
    index2 = weatherString.indexOf('~', index1 + 1);
    todayForecast = weatherString.substring(index1 + 1, index2);
    index3 = weatherString.indexOf('~', index2 + 1);
    dayoneHigh = weatherString.substring(index2 + 1, index3);
    index4 = weatherString.indexOf('~', index3 + 1);
    dayoneForecast = weatherString.substring(index3 + 1, index4);
    index5 = weatherString.indexOf('~', index4 + 1);
    dayoneLow = weatherString.substring(index4 + 1, index5);
    index6 = weatherString.indexOf('~', index5 + 1);
    daytwoHigh = weatherString.substring(index5 + 1, index6);
    index7 = weatherString.indexOf('~', index6 + 1);
    daytwoForecast = weatherString.substring(index6 + 1, index7);
    index8 = weatherString.indexOf('~', index7 + 1);
    daytwoLow = weatherString.substring(index7 + 1, index8);
    index9 = weatherString.indexOf('~', index8 + 1);
    daythreeHigh = weatherString.substring(index8 + 1, index9);
    index10 = weatherString.indexOf('~', index9 + 1);
    daythreeForecast = weatherString.substring(index9 + 1, index10);
    index11 = weatherString.indexOf('~', index10 + 1);
    daythreeLow = weatherString.substring(index10 + 1, index11);
  else Serial.println("Not tonight");
void getDayWeather(const char *event, const char *day_data)
  String name;
  String weatherString = String(day_data);
  Serial.println(day_data);
  if ((name == "Today") || (name == "This Afternoon"))
    todayHigh = weatherString.substring(index0 + 1, index1);
    todayLow = weatherString.substring(index2 + 1, index3);
    dayoneHigh = weatherString.substring(index3 + 1, index4);
    dayoneForecast = weatherString.substring(index4 + 1, index5);
    dayoneLow = weatherString.substring(index5 + 1, index6);
    daytwoHigh = weatherString.substring(index6 + 1, index7);
    daytwoForecast = weatherString.substring(index7 + 1, index8);
    daytwoLow  = weatherString.substring(index8 + 1, index9);
    daythreeHigh = weatherString.substring(index9 + 1, index10);
    daythreeForecast = weatherString.substring(index10 + 1, index11);
    index12 = weatherString.indexOf('~', index11 + 1);
    daythreeLow = weatherString.substring(index11 + 1, index12);
  else Serial.println("Not today");
void drawWeatherBitmap(int x, int y, String forecast)
  if (!strcmp(forecast, "Sunny"))
    timeCanvas.drawRGBBitmap(x, y, sunny, 40, 40);
  if (!strcmp(forecast, "Mostly Sunny"))
    timeCanvas.drawRGBBitmap(x, y, partial_cloudy, 40, 40);
  else if (!strcmp(forecast, "Clear"))
    timeCanvas.drawRGBBitmap(x, y, moon, 40, 40);
  else if (!strcmp(forecast, "Mostly Clear"))
  else if (!strcmp(forecast, "Partly Cloudy"))
    timeCanvas.drawRGBBitmap(x, y, cloudy, 40, 40);
  else if (forecast.indexOf("Cloudy") > 0)
    timeCanvas.drawRGBBitmap(x, y, cloud, 40, 40);
  else if (!strcmp(forecast, "Showers"))
    timeCanvas.drawRGBBitmap(x, y, rain, 40, 40);
  else if (!strcmp(forecast, "Windy"))
    timeCanvas.drawRGBBitmap(x, y, windy, 40, 40);
  else if (forecast.indexOf("Rain") > 0)
  else if (forecast.indexOf("thunder") > 0)
    timeCanvas.drawRGBBitmap(x, y, rain_thunder, 40, 40);
  else if (forecast.indexOf("Snow") > 0)
    timeCanvas.drawRGBBitmap(x, y, snow, 40, 40);
  else if (forecast.indexOf("Overcast") > 0)
void ledBlink(void)
  digitalWrite(LED_BLUE, LOW);
  digitalWrite(LED_RED, LOW);
  for (int r = 0; r < 4; r++)
    digitalWrite(LED_RED, HIGH);
    delay(30);
    delay(30);
  for (int b = 0; b < 4; b++)
    digitalWrite(LED_BLUE, HIGH);
    delay(30);
    delay(30);
@AndreHell, you won't see anything if you don't power the backlight on the display. Since that display has a transistor driving the BL, you can control the BLK input with a GPIO from the Photon 2. A HIGH on the pin you chose will turn on the backlight. In my case, I turn it off to save power when the display is not looked at overnight.
Hi peekay123, I think the problem lies in the assignment of the pins. Can this be? Did I miss something? Unfortunately, controlling BLK didn't make any changes.
Maybe you want to start with the simplest of examples to get the display running at all to keep any potential "distractions" out.
I'd also use SYSTEM_THREAD(ENABLED) to make sure flaky cloud connections wouldn't interfere.
@AndreHell, I agree with @ScruffR that you should run a simpler example for testing.
Both the Boron and Photon 2 are Feather-based boards, meaning their pinout is mostly the same. In either case, you do not need to specify TFT_SDA or TFT_SCL since the SCK and MOSI pins are predefined in DeviceOS. The Boron A4 pin maps to the Photon 2 S4 pin while the Boron A5 pin maps to the Photon 2 S3 pin. So based on this and the wiring diagram above, I believe you should have the following definitions:
#define TFT_RST S3
#define TFT_DC S4
BTW, you still need to enable the BLK input so the backlight comes on.
Just to be completely clear: The original project used a TFT LCD display and the BLK pin needs to be driven. LCD displays need a backlight. This display uses 7789 controller.
The subject that @AndreHell posted under says OLED display. OLED displays don't have backlights, and they might or might not use the 7789 controller.
So my question is, what display are you actually using and what controller chip does it have?
Hello bko,
oh sorry, that's my mistake. I use these Display.
1.3 inch IPS HD TFT ST7789 Drive IC 240 * 240
OK then PK is right--you need the backlight.
I would try to get a simple sketch with any text on the display working first, then move on to more complex things like the code from github.
Hello everyone, thank you for your help.
The project is now running.
Without the BLK connection.
Thank you all.
Great that you got it working! For completeness, you might want to let everyone know what the fix was.
