Offspring Exit Notification ***New Version***
My youngest is now capable of opening exterior doors and while we always tell him not to unlock or open the door without us present we always worry that he might slip out without us seeing or hearing him. So off to the garage!
I used a normally closed door contact, Adafruit PermaProto board, 2 x single row female headers & a terminal block I had in the parts bin.
The Photon sends the Particle.publish message that is sent to Pushover.net via a Webhook and virtually instantly arrives on both my phone and my wife’s phone.
New version I built so that me and the wife can open the door without triggering the alert.
The idea is that the kids are under 5’ tall so I mounted the device so that me and my wife will trigger the sensor as it is setup at about the 5’ tall area. I have the onboard LED set to turn on when it detects us so that we know its safe to open the door without triggering the alert.
New version utilizes a HC SR04 Ultrasonic sensor.
Version 2
V2 Photon Code
#include <HC_SR04.h>
double cm = 0.0;
double inches = 0.0;
int led1 = D7;  // we will use the built in LED for a visual door open indicator
int Input1 = D6; // define the pin used for the door sensor
int lastState = 0; // set the default state
String Distance;
// Setup HC-SR04 trig & echo pins
int trigPin = D4;
int echoPin = D5;
HC_SR04 rangefinder = HC_SR04(trigPin, echoPin, 5.0, 61.0);
   pinMode(led1, OUTPUT);
   pinMode(Input1, INPUT_PULLUP);
   pinMode(trigPin, OUTPUT);
   pinMode(echoPin, INPUT);
   Particle.variable("cm", &cm, DOUBLE);
   Particle.variable("inches", &inches, DOUBLE);
   int Input1State;
   inches = rangefinder.getDistanceInch();
   cm = rangefinder.getDistanceCM();
   Distance = String(inches);
   delay(100);
   Input1State = digitalRead(Input1); // Turn onboard LED on when we are detected by the sensor
   if (inches > 2) {
        digitalWrite(led1, HIGH);
    else if (inches == -1) {          // turn off onboard LED when we are not detected by the sensor
        digitalWrite(led1, LOW);
   if (((Input1State == HIGH) && (lastState == 0) && (inches == -1))) {
     Particle.publish("Offspring_Alert","Back Door Open", 10);
     lastState = 1;
    else if (((Input1State == LOW) && (lastState == 1) && (inches == -1))) {
    Particle.publish("Offspring_Alert","Back Door Closed", 10);
    lastState = 0;
   if (((Input1State == HIGH) && (lastState == 0) && (inches >= 2))) {
//     Particle.publish("Offspring_Alert","Back Door Opened by Adult", 10);
     lastState = 2;
    else if ((Input1State == LOW) && (lastState == 2)) {
    lastState = 0;
Version 1
V1 Photon Code:
   int Input1State;
   if ((Input1State == HIGH) && (lastState == 0)) {
     lastState = 1;
else if ((Input1State == LOW) && (lastState == 1)) {
    lastState = 0;
Sweet!
Now just attach a Particle GPS Asset tracker to him and if he does get it out you can track him down pretty quickly :wink:
until he figures out, or one of his friends shows him he just needs to wave a hand or broom over the sensor to fool it. :slight_smile:
Indeed it is not impossible to bypass, However for the present time it should do fine. If he gets creative I have biometric access controls I can implement :slight_smile:
Nice way to automatically disable the Alerts!
This would be good for keeping the fridge locked also in the near future :smile:
I’ve been testing a few proximity sensors latley also.
If you want to use hand gestures to lock or unlock stuff look at the ADPS-9960 and if you want a super small and accurate long range distance sensor check out the https://www.adafruit.com/product/3317?gclid=CJCuwdufz9MCFclKDQodth0A2w
Both have working Particle libraries avaliable.
I must say, I was expecting some sort of alarm for your pregnant wife to communicate with you when she was going into labor. :smiley: Very cool, nonetheless.
