Hi All,
I'm looking for some help with a modbus query. We are currently using an rfid reader on our devices. Please see below for some snippets from the rfid reader manual:
We have been communicating with the reader using Serial1, where I am manually writing the command bytes to Serial1 with write. The main command we are using is the command in 4.1. After sending the command, I then check if Serial is available and manually read the bytes into an array, and then do the CRC check manually. I have a feeling that this manual approach may not be the optimal way to do it.
I have been trying to achieve the same functionality using the ModbusMaster library, but having some issues. Here is my current approach:
From the reader manual to read all tag data, I need to send the following command to the reader:
byte lookup_read_tag_data[] = {0x02, 0x03, 0x00, 0x16, 0x00, 0x0A, 0x24, 0x3A};
From this command we see the readers address is 02 and 03 represents the read function. From the ModbusMaster.h file it seems like this function code should correspond with:
// Modbus function codes for 16 bit access static const uint8_t ku8MBReadHoldingRegisters = 0x03; ///< Modbus function 0x03 Read Holding Registers
For the above reason I have been trying to get this to work with
result = node.readHoldingRegisters(0x16,10);
Serial.println("");
Serial.print("Read Coils Response: ");
Serial.println(result, HEX);
With node.enableDebug(); it looks like I am sending the correct command to the reader:
Read Coils Response: E0
TX: 2 3 0 16 0 A 24 3A
RX: 81 74 31 2 3
RX: FF 2 3 8 FF
RX: 81 74 31 74 31
RX: 54 2 3 8 FF
RX: 81 74 31 2 3
RX: FF 2 3 8 FF
RX: 81 74 31 2 3
I know that the debug can break the comms, but it seems like I am sending the correct command to the reader. Based on the RX responses, I am pretty sure the issue here is a timing issue, as I can see repeating sequence on the RX outputs.
From the reader manual, the reader should respond to this command with 25 bytes. So my current questions are as follows:
- Should I stick to my homebrew Serial1.write and read solution rather than trying to implement the Modbus solution?
- Am i using the correct Modbus function to send the command to the reader, or should I be manually sending the bytes with a different command in the library?
- I am obviously not using the Modbus library correctly, as it thinks its getting the wrong reader address, but I think this is just as a result of the RX being out of sync. How do I offset, or tell modbus how many bytes the reader should be responding with? I have tried a few different values for the second argument in readHoldingRegisters, but this has not seemed to help much.
Any advice or help is greatly appreciated.
