In order to run a battery project I’ve been experimenting with Spark.publish and System.sleep in deep sleep mode. I now have three Photons with the same code and firmware 0.4.4 but only 2 of them wake up after sleeping; the third runs through the code once, sleeps and never comes back.
I have seen other threads reporting problems with sleep but it’s unclear to me if they still exist in 0.4.4 and I appear to have Photons with different behaviour (hardware levels? marginal Photon? deep firmware differences?).
Is System.sleep still suspect or should it work on a Photon as advertised?
Can anyone explain the Photon differences or suggest what I might check?
PS. It may have been the recent update to 0.4.4 firmware but I had a lot of trouble flashing the Photons and spent some time flashing different code on them before I was satisfied they were all running the same code.
PPS. The code I’m using is below and started from @bko getting started with Spark.publish with an added self subscribe to check the publish is complete and then a SLEEP_MODE_DEEP at the end.
char publishString[40];
unsigned uptimeFlag;
unsigned sleepEnable;
void myHandler(const char *event, const char *data) {
if (strcmp(event,"Uptime")==0) {
uptimeFlag = 1;
void myHandler2(const char *event, const char *data) {
if (strcmp(event,"Sleep-off")==0) {
sleepEnable = 0;
if (strcmp(event,"Sleep-on")==0) {
sleepEnable = 1;
sleepEnable = 1;
Spark.subscribe("Uptime", myHandler, MY_DEVICES);
Spark.subscribe("Sleep", myHandler2, MY_DEVICES);
unsigned long now = millis();
unsigned millis = now%1000UL;
unsigned nowSec = now/1000UL;
unsigned sec = nowSec%60;
unsigned min = (nowSec%3600)/60;
unsigned hours = (nowSec%86400)/3600;
sprintf(publishString,"%u:%u:%u.%04u ",hours,min,sec,millis);
uptimeFlag = 0;
Spark.publish("Uptime",publishString, 60, PRIVATE);
for(int i=0;i<50;i++){
delay(100);
Spark.process();
if (uptimeFlag) break;
RGB.control(true);
if (uptimeFlag) RGB.color(0,255,0);
else RGB.color(255,0,0);
for(int i=0;i<10;i++){
delay(100);
Spark.process();
while (sleepEnable==0) {
RGB.color(0,0,255);
delay (1000);
Spark.process();
System.sleep(SLEEP_MODE_DEEP, 5UL);
